What happened to the other Legend Brian
Still driving it for now prob another week or two till I switch
Could u provide the link where u purchased the poly mounts?
- Sent from my iPhone 6 using Tapatalk |
http://forums.acuralegend.org/polyed...nd-t26530.html |
Rotated and balanced tires, installed rear tie bars, 4 wheel alignment (again), washed and waxed......
http://i289.photobucket.com/albums/l...ps6625a73e.jpg http://i289.photobucket.com/albums/l...ps1bb2cf5b.jpg http://i289.photobucket.com/albums/l...ps9b081106.jpg |
Welp, these are toast, pretty much all of them. And they ruined my 1yr old rotors :/. Should've replaced them forever ago....
Found my non-engaged low mph brake squeak though, lmao... I smell a mini bbk soon. http://i57.tinypic.com/20tf85h.jpg |
Installed the remainder of the rear tie bar set. Oh and YES I'm loving it thus far!! :ihih:
http://i729.photobucket.com/albums/w...ps23189bfa.jpg We had ourselves a little mini meet. Shout out to Jonslegend, Rita, Chase and Bradley, Justin and MrPeacock72. Unfortunately not everyone was there together for a daytime photo. :( http://i729.photobucket.com/albums/w...ps1b383fde.jpg http://i729.photobucket.com/albums/w...psd365edeb.jpg |
Bought some ricer ass shit to put on it.
Got 4 months til NALM, and I've set a few goals. |
Took a trip up to CT to see the legend doctar to get my rear main seal fixed
http://i821.photobucket.com/albums/z...psb51vt605.jpg |
i want to hear this soo bad
found out I have 2 flat tires and possibly a bent wheels fucking pot holes
http://i.imgur.com/4jA5PpN.jpg |
yepp, wanna hear that beast up there too.
today? finally found the mystery leak that's been makin' a mess on the front of my engine. It looks like the it's the o-ring #29 that connects to the high pressure Power Steering hose. http://stores.revolutionparts.com/oe...6-speed-manual part number 91370-SB3-950 it looks easy enough to get to. my guess is that the headers have put off so much heat into the high pressure hose line that it helped fry that 21 yr old o-ring. we shall see if that was the problem though after I put in the new o-ring and some thermo-tec wrap on that line |
Finally mixed and matched a good set for dat burlwood life.
http://i.imgur.com/7diHNpl.jpg?1 http://i.imgur.com/aNUrs4e.jpg?1 http://i.imgur.com/fRj0qAE.jpg?1 http://i.imgur.com/7ppsapp.jpg?1 http://i.imgur.com/y2xNJSx.jpg?1 |
oooo lookin good!
Parts!!!
Picked up Felpro head set, no rings just yet. Admired jacked-up stance (drivetrain removed)in driveway, looks like a gasser or low low
New right front, left rear calipers, and left rear rotor. All new pads, but will work my way around to all new rotors and calipers eventually.
Also got all the crap that has accumulated in my trunk the past winter. I had replaced the pc680 battery with the XS 1200 a month ago, but finally moved it over to the passenger side. A little tidying up, and he'll have a home in her cubby. http://i58.tinypic.com/vat7s.jpg |
Time certed my oil pan today. Over sized plug wouldn't stop leaking. So went to Honda and used the special tool. Perk of being a mechanic i guess lol
Oil and trans fluid change. Check out the 1986-87 canister oil filter housing!
https://farm8.staticflickr.com/7101/...b60077_b_d.jpg |
Big brake kit rotors showed up :)
I put the stock suspension back on the SE
https://scontent-a-iad.xx.fbcdn.net/...15025298_n.jpg still have some work on the corner before I can roll it into the garage and start ripping out the motor. https://scontent-b-iad.xx.fbcdn.net/...75041547_n.jpg I cleaned the rest of the Honda used car lot https://scontent-b-iad.xx.fbcdn.net/...57652648_n.jpg and then procceeded to slam the coupé to the ground https://scontent-a-iad.xx.fbcdn.net/...13176075_n.jpg |
Looking good Rich. I can't wait to see the coupe in Los Angeles.
I looked at the pollen and crap on my car and did nothing about it today. |
Thanks Kevin.
Would you prefer winter. ??? AtLeast there isn't any salt left on the road |
I put a key for the wrong Legend in the ignition.... spent the next couple hours trying to get it out.
Prepped my new dash for paint, took apart my climate control panel and instrument cluster to get them ready for LED's and chrome rings.
Blew my diff up :(
Stupid tapatalk
She has never been on one of these before
http://img.tapatalk.com/d/14/04/09/je2apema.jpghttp://img.tapatalk.com/d/14/04/09/ugagepyg.jpg |
I feel your pain Jon.
