Old 02-24-2012, 12:00 AM   #1
greenswisher
greenswisher's Avatar
Real Name: Alex
greenswisher is on a distinguished road
Default Lights dim for a sec when brake applied, turn signal, and climate control used
I was just driving and all of the sudden, every time I pushed the brake pedal, turned on the heat, or used my turn signal, my headlights and all interior lights dim for a second. At one point my head unit turned off and back on. This started happening right after I got gas, only accessories on were lights and heat on low. I dont have subs/amps. I do have HID headlights and the left one hasn't been working. Not sure if that would cause any issues. Also I recently installed tail lights from the jy, again not sure if that has anything to do with the issue. Any help is greatly appreciated, thanks
greenswisher is offline   Reply With Quote
BRAKE LIGHTS WON'T TURN OFF jclegend 2nd Gen. Legend General Discussion 12 07-19-2011 06:52 AM
Sedan front turn signal lights or lenses jacksonww OEM Parts 6 04-03-2011 11:50 AM
WTT: Turn signal switch terragotti OEM Parts 6 10-22-2010 10:47 PM
turn signal issue mark evans 1st Gen. Legend General Discussion 4 09-07-2010 07:35 PM
FS: Clear G2 Coupe Turn Signal Lights Olikado Non-OEM Parts 4 03-26-2010 10:47 PM
