Old 08-25-2009, 03:15 PM   #1
mobile-6
mobile-6 is on a distinguished road
Angry turn on park lights fuse 49 blows out
I have a 1991 acura legend 4 door sedan. when i turn on the park light the fuse blows out. the two front park lights not working. the right rear tail light not working. but the head lights come on, the left rear tail light works. when i turn the switch to the headlight position. i can remove the tail light relay and turn on the headlight switch and the fuse is ok, but no front or rear lights, soon as i install the relay the fuse 49 blows out, i unplug the front lights, the rear lights, the dimmer switch , and the fuse still blows out.
mobile-6 is offline   Reply With Quote
Old 08-25-2009, 03:24 PM   #2
mobile-6
can i please get some help
Old 08-25-2009, 03:38 PM   #3
captain cheeseman
Girls are my passion
captain cheeseman's Avatar
captain cheeseman is on a distinguished road
Send a message via AIM to captain cheeseman Send a message via MSN to captain cheeseman Send a message via Yahoo to captain cheeseman
check the grounds on the wiring. my left corner light wasnt working because of a faulty ground.
names kyle.
I never back down from a challenge even if it involves my car.
i heart cheese.
captain cheeseman is offline   Reply With Quote
Old 08-25-2009, 05:01 PM   #4
Quaraxkad
Moderator?
Quaraxkad's Avatar
You probably have a wire cut/pinched somewhere and grounding out against the frame or body. Look at the wiring diagrams and test each component on fuse 49 until you find the one that blows the fuse, follow the wires and look for breaks.
Old 08-26-2009, 11:08 PM   #5
mobile-6
what about a bad combination switch
Old 08-27-2009, 08:49 PM   #6
mobile-6
I located the short on the driverside fender at the marker lights. thanks
94L Sedan, A/T, shifter stuck in Park CT-Legend 2nd Gen. Legend General Discussion 15 07-14-2010 10:42 AM
Fuse Panel Losaun 2nd Gen. Legend General Discussion 4 08-18-2009 01:25 AM
Can you park a little closer, jerk? DevanTheDude The Water Cooler 64 07-19-2009 07:06 PM
SoCal Monterey Park Meet 10/19/2008 kotetu Meet Photos 0 06-27-2009 09:58 AM
