Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > General DIY Discussions > Wheels & Tires
Old 12-06-2009, 07:20 AM   #1
MemberLS02
MemberLS02 is on a distinguished road
Default Will 17x8.5" w/65 offset fit on rear of G2 Coupe?
Pretty much like the title says: Will 17x8.5" w/65 offset fit on rear of G2 Coupe? I know it wont fly for the front since I heard the max for the front on a 7.5" width is +55, therefore could it work if changing numbers around a bit to an 8.5" width on rear and +65 offset?
According to some research I've done and utilizing the Wheel Offset calculator, were talking about 25mm less clearance on the inside of the wheel, but can that work for the G2 Coupe back there? I know that some have gotten away with as much as +51 offset in the rear on an 8.5" width wheel (ex. EarlThePearl), so hopefully there is still room for more.
Thanks!
MemberLS02 is offline   Reply With Quote
Old 12-06-2009, 07:32 AM   #2
i think it'll hit the strut assembly.
Old 12-06-2009, 08:17 AM   #3
-X-
GS MAXXX
-X-'s Avatar
Send a message via AIM to -X-
that should work, i got away with a 45 offset with a 8.5 wide rim
Old 12-06-2009, 08:29 AM   #4
MemberLS02
Well with that offset, clearing on the inside suspension components wouldn't be a factor at all since you're in essence pushing the rim towards the outside more by running with a lower offset. Nice set up by the way.
Old 12-06-2009, 08:33 AM   #5
UNCLEgend
Stay Thirsty!!
UNCLEgend's Avatar
UNCLEgend is on a distinguished road
^ +1 A bit too wide for that offset. Will likely hit suspension.
Artist Previously Known as "go92Legend" = Gerry
<Work><Akebono><Powerslot><Koni><Remus><MLS Copy><Addco><Fut Tie Bars><JDM-HID-PIAA><Red-Black Calipers><Alpine>
UNCLEgend is offline   Reply With Quote
Old 12-06-2009, 08:33 AM   #6
There's only about 10-15mm btwn the rim and strut on my car. (it's lowered so there was camber). It's gonna be really close if it fits
Old 12-12-2009, 06:28 PM   #7
onthe3rdday
onthe3rdday's Avatar
onthe3rdday is on a distinguished road
Thanks!
8" with + 60 works front or rear. 8.5" +65 should be game, what tire are you running and are you lowered? I'm assuming it works because it calculates to 11mm less clearance on the inside. S2000 wheels are cheap(~$150 shipped) if you are looking for a guinea pig wheel with those specs.
onthe3rdday is offline   Reply With Quote
Old 12-13-2009, 07:56 AM   #8
I'm with Alperovich it's going to be a tight squeeze.
and it might hit under driving.
Old 12-13-2009, 08:20 AM   #9
I agee it'll be REALLY close if it does fit and the chances of it hitting while driving over any bumps are pretty significant imo.
EDM "washing fluid" sensor and rear fog light pictures eugene 2nd Gen. Legend General Discussion 5 10-13-2009 12:21 PM
Will coupe drivers seat fit in sedan ari_one 2nd Gen. Legend General Discussion 7 08-17-2009 05:57 AM
FS: Good running, black '92 LS with "bent" rear end PhyllBeach Legend 7 06-30-2009 12:09 PM
G2: My "95" Legend Coupe. dannymyboy Second Gen Legend Gallery -- 1991 - 1995 21 06-08-2009 03:06 PM
Wheel weight offset size ie will this fit? Telion 2nd Gen. Legend Performance Enhancements 8 06-04-2009 12:20 AM
