Old 02-02-2024, 02:25 PM   #1
Default Trunk lid holding water
1990 Acura Legend Sedan. When I open the trunk lid all the way after a rain, water runs out at either corner near the velcro flaps. 3 or 4 ounces.
Anyone else have this problem, or know what the cause is, or know how to fix it?
I noticed there is a tiny arched opening in the metal on each side that might be some sort of drain. They are barely bigger than a toothpick. If so, wondering if they got clogged.
I tried to remove the inner liner, but can't figure out how to remove the plastic cover over the trunk latch. Does it just pop off? One side came loose easily but I'm hesitant to apply too much force to the other side.
Old 02-04-2024, 04:04 PM   #2
paulo57509
paulo57509's Avatar
I wonder how the water is getting in between the outer and inner structure of the lid?
The service manual isn't much help. It's attached anyway.
'87 L-Coupe 5-Speed
Stock; Few Mods
445K Miles - original engine and drivetrain.
Old 03-15-2024, 12:57 PM   #3
paulo57509
paulo57509's Avatar
Did you ever figure out where the water is coming from?
Isn't the badging on the trunk face (LEGEND) bolted on? Could it be getting in thru there?
'87 L-Coupe 5-Speed
Stock; Few Mods
Old 03-15-2024, 06:50 PM   #4
90Legend L
G1 Driver
90Legend L's Avatar
90Legend L is on a distinguished road
Going from memory... that plastic around the trunk latch has plastic tabs that are staked into clips in the metal. Use a flat screwdriver to pry gently around the clip area and they'll give way. Sounds like there is a plugged drain. The drain should be the diameter of a pencil.
1990 Legend L Sedan, was Auto, now 5 spd
mostly Bahama Gold Metallic; 380k miles
Lee King coolant lines
Tappan lifters
Smoketronic oil level control
90Legend L is offline   Reply With Quote
Old 03-16-2024, 08:42 PM   #5
Haven't figured it out yet.
The badges are stuck on with double sided foam tape.
Water Leaking in Trunk slushpuppy35 2nd Gen. Legend General Discussion 16 03-06-2013 04:30 PM
G2 coupe trunk carpet - under the trunk lid, spare tire cover, and the plastic trim Mike Diaz OEM Parts 9 04-17-2012 09:03 AM
Question On Water In Trunk 91boz 2nd Gen. Legend General Discussion 8 06-23-2011 05:27 PM
Water in trunk??? MasTeR.LeGenD 2nd Gen. Legend General Discussion 25 10-20-2010 10:38 AM
