11-21-2009, 06:33 PM | #1 |
ABS/TCS Issue
"C.K. El Presidete" |
11-22-2009, 06:24 PM | #2 |
**Bump**
Anyone!!
11-22-2009, 06:33 PM | #3 |
This is confusing because there is no code for 1 short blink. However there is a code 1 (no sub code) which is Pump motor overrun. I can't confirm whether that code would be 1 long blink or 1 short blink
Does the light stay on everytime you start the engine? You can always pull the ALB 2 fuse and reset the memory and see if the problem keeps happening |
11-22-2009, 06:37 PM | #4 |
That is "1 long w/no sub-code'. Means "pump overrun" in technical lingo. Means toasted ABS pump/modulator in street talk (more likely than not).
11-22-2009, 06:37 PM | #5 | |
11-22-2009, 06:38 PM | #6 |
So the pump is fried is that what you are telling me? I can jump the relay and the pump runs
11-22-2009, 06:44 PM | #7 |
Yes, the pump will run but no pressure ever builds so the pump continues to run and then the computer senses the "pump overrun" and disables the system and turns the light on. I had the same issue with my 91 LS Sedan and changed out the whole pump/mod assembly with success.
11-22-2009, 06:46 PM | #8 | |
11-22-2009, 06:51 PM | #9 |
I hope it is but that is wishful thinking. There is no pressure inside of the brake fluid reservoir. Unless all of your fluid has splashed out.
11-22-2009, 06:52 PM | #10 |
Thanks Bro.... Is there anything I can check at the junkyard to determine if the ABS is good or not? Also does this affect the TCS ?
FS: TCS Module, $30 | The Crowing | OEM Parts | 4 | 10-03-2010 04:30 PM |
BRAKE ABS TCS light on | okie dokie | 2nd Gen. Legend General Discussion | 10 | 11-17-2009 09:37 AM |
TCS on a type I.. possible?? | Romero88 | 2nd Gen. Legend General Discussion | 18 | 10-02-2009 06:35 PM |
tcs intake.... | hotstartup | 2nd Gen. Legend General Discussion | 9 | 08-14-2009 10:57 PM |
ABS and TCS lightz on my GS | bdok91 | 2nd Gen. Legend General Discussion | 4 | 06-04-2009 04:34 PM |
