Old 07-14-2009, 07:54 AM   #1
Apex|000
日本児童
Apex|000's Avatar
Default Steering issue
Okay when i drive my car i constantly have to hold my steering wheel to the left to prevent the car from swaying to the right, and my steering wheel is also a bit loose. (like i can move the steering wheel left to right and not much will happen)
anyone have anythoughts of how those two can be fixed ? because the Lord knows it's annoying.
Thanks
Old 07-14-2009, 08:03 AM   #2
Apex|000
日本児童
Apex|000's Avatar
Wrong section, please move to second generation.
Old 07-14-2009, 08:25 AM   #3
posting section failure... LOLOL!
Old 07-23-2009, 02:50 AM   #4
pmendoza502
pmendoza502 is on a distinguished road
actually i am having the same issue on my 99 rl, gona try an alignment...
pmendoza502 is offline   Reply With Quote
Old 07-28-2009, 07:22 PM   #5
Apex|000
日本児童
Apex|000's Avatar
i'm going to try the same thing also, hopefully it will fix it
Old 07-28-2009, 09:39 PM   #6
ari_one
MeltingInTheSun
ari_one's Avatar
An alignment should fix the pulling unless you have a loose/bent part or bad tire. Also your rack may also need to be adjusted or may be going bad, hopefully you are running Acura/Honda power steering fluid!!
Old 07-29-2009, 01:45 AM   #7
alittlethin
alittlethin's Avatar
alittlethin will become famous soon enough
bad tie rods ?
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it??
Come on man, don't take it so serious. It takes a lot of comitment and pride to throw money into something that will never yield a 16th back.
~Dv8
alittlethin is offline   Reply With Quote
Old 07-29-2009, 01:57 AM   #8
dumplingcorps
Stone-Hearted
dumplingcorps is on a distinguished road
gonna be funny when all you need is more air on one tire. anyway, did you hit anything or did anything hit you? if not then i dont think anything should be bent. tie rods could be suspect, did you recently change them? if so they could be mis-adjusted. i say get an alignment first, they usually tell you if you have a bended part. i just think you need an alighnment. sorry for long post, im DRUNK....
dumplingcorps is offline   Reply With Quote
I Need Help.. Steering Tilt Wayne-A-Ferd 2nd Gen. Legend General Discussion 5 06-19-2009 01:06 PM
Steering wheel options whats77inaname 2nd Gen. Legend General Discussion 9 06-15-2009 07:08 PM
Weird electrical issue LegendJeff 2nd Gen. Legend General Discussion 6 06-14-2009 08:15 PM
DIY: Steering Rack Removal sam o nela First Generation Legend (1986 - 1990) 0 06-03-2009 02:26 PM
DIY: Steering Slack Fix sam o nela First Generation Legend (1986 - 1990) 0 06-03-2009 11:49 AM
