Old 02-12-2012, 09:20 AM   #1
1988G1
1988G1 is on a distinguished road
Default compression tested
i guess its time for a new heart for my legend. cly 1,2,3 gets 80 compression and 4,5,6 is at 100. i gotta make a trip. wasington to cali. what you guys think.
1988G1 is offline   Reply With Quote
Old 02-12-2012, 11:45 AM   #2
kongbuiltt
Dissizit!
kongbuiltt's Avatar
kongbuiltt is on a distinguished road
I would not.
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Simple enough.
kongbuiltt is offline   Reply With Quote
Old 02-12-2012, 12:30 PM   #3
awelliott
Senior Junior Member
Real Name: Tony
awelliott will become famous soon enough
It would be nice to have more info, such as how it is currently performing, oil consumption, etc. However, considering the info given, I don't think it's that risky - just keep an eye on the oil level and don't drive like a maniac. Good luck...
awelliott is offline   Reply With Quote
Old 02-12-2012, 02:20 PM   #4
Djets
Real Name: Don
Djets is on a distinguished road
I agree, more info would be good. But, 80 psi on one bank and 100 on the other is 20% difference instead of the desired 10% rule in compression testing an engine. And that rule usually refers to comparison of cylinders, not banks of an engine.
Even if I didn't have antifreeze in my oil and it was still running, I would be saving the cash for future work; heads or a 3.5 swap that is. We've seen the 3.2 just can't tolerate an imbalance and usually results in the BHG. The 3.5 swap seems to be the better option for most. I'm going there soon, as I'm not going to pay for a second BHG on my 3.2. My 2 cts.
You are in the right forum for any help you might need my friend. Good luck to you no matter what the decision.
Don
Djets is offline   Reply With Quote
Old 02-12-2012, 04:25 PM   #5
1988G1
thanks for the reply guys. i know for sure i dont have a BHG. oil, coolant, and temp is fine. i do know my rear motor mount is bad. the mechanic said my timing belt might of jump a teeth. what kinda of damage can cause if it did jump a teeth on the timing belt? oh and my ecu is reading that my bank2 o2 sensor is bad but no engine light on. yes i have replace it with a new one. ecu is still saying its bad.
Old 02-12-2012, 07:12 PM   #6
awelliott
Real Name: Tony
What's with the timing belt - is your mechanic saying that the timing belt slipping a tooth is the cause of the low compression? In any event, if the timing belt is the least bit suspect, then I'd have it investigated further. If it has slipped one tooth, what's to stop it from slipping several teeth? If it does that, then it's new engine time because these are interference engines and the pistons will adjust your valves the hard way.
The timing belt is a game changer. I wouldn't take a trip unless I ruled it out. If the timing is off, then I suppose you could correct it and see if it improves the compression - if so, then you could replace the belt/tensioner/water pump if it's due. If you set the timing and the compression is still low, then I wouldn't bother with the expense of replacing the belt since you have major internal engine issues. You could also investigate the cause of the low bank further by doing a leak-down test. However, the fact is that the readings on your "good" cylinders aren't so hot, so it might be a waste of time.
Old 02-12-2012, 07:33 PM   #7
Don
hgeez: I bet you didn't realize you were in the G1 section eh? lol
Old 02-13-2012, 03:05 PM   #8
The fact that the compression is different between banks, and the mention of the timing belt maybe slipping a tooth suggests that the timing may have slipped on the rear cam (or slipped more on the rear cam) and correcting it may improve things. I second Tony's recommendation that you thoroughly investigate the timing belt before starting on a long trip. Do you know how many miles/years since the timing belt was changed?
Old 02-14-2012, 06:41 PM   #9
1988G1
i found jdm motor for sell local. they want one for 5oo bannana. what you guys think. let me know. so i can start the heart trans plant. what do i look for as legit jdm.
Old 02-14-2012, 07:48 PM   #10
uniquelegend
Legend Enthusiast
uniquelegend's Avatar
uniquelegend is on a distinguished road
lol, tell them to open up the valve covers. 500 is a good deal if they ship free or maybe you can pickup. dont forget to ask if they have a warranty and if the motor been compression tested with proof.
good luck, i wish i could be there.
Cardomain
http://www.cardomain.com/ride/2943300
uniquelegend is offline   Reply With Quote
3.5 flow bench tested. Jonslegend 2nd Gen. Legend Performance Enhancements 58 06-28-2010 04:32 AM
AEM cold start tested today Car2n The Water Cooler 10 12-11-2009 12:34 AM
My compression on all my cylinders 95pearlwhiteGS 2nd Gen. Legend General Discussion 16 12-01-2009 11:56 AM
compression? the gold version 2nd Gen. Legend General Discussion 20 09-30-2009 08:31 PM
