Real Name: A King!
OK, so it seems if I don't let my car warm up on a cold morning before driving, I'll get the CEL about 5-10 mins after I drive off. But when I let it warm up, its fine and no CEL. Anyone know what this is about?
Can I still pull the codes even though the CEL doesn't always come on? Like I want to go out and try to pull the codes now, but I have seen the CEL in awhile. |
Check out the Cel thread (use search function)
#3 | |
The Innovator
Real Name: Ray
![]() Quote:
Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. |
Real Name: A King!
That's what I did before writing this. I never have much luck with the search option. There was some useful links in my other thread. If you see any links worth while, please send. Thanks.
#5 |
Real Name: A King!
Ok so has anyone ever had a CEL on but no codes?
#7 |
I think that means bad ECU
#8 | |
Real Name: A King!
![]() Quote:
Bad ECU? So I'm assuming this is Code 0 on the list? The ECU is the computer correct? Sounds expensive... Last edited by Aking; 01-31-2010 at 01:18 AM. |
#9 |
How long did you unplug the battery for? It's supposed to be for 10 secs. When you pull the fuse, pull it for 10. Yes the ECU is on the passenger side. When you peel back the carpet to check the codes, you see the metal cover that goes over the ECU.
#10 |
Real Name: A King!
I had it unplugged for more like 2-3 minutes.
Check engine light!!!! still!!!!! | gibbsrcing | 2nd Gen. Legend General Discussion | 35 | 07-18-2013 09:56 PM |
Engine Codes 43 44 46 | kenyan83 | 2nd Gen. Legend General Discussion | 0 | 11-18-2009 12:20 PM |
Check Engine Light | Dandog | 1st Gen. Legend General Discussion | 3 | 07-27-2009 07:48 PM |
Pulling ABS codes | GreekPower | 2nd Gen. Legend General Discussion | 21 | 07-08-2009 06:10 PM |
ECU CEL light code translation | Telion | 2nd Gen. Legend General Discussion | 0 | 06-03-2009 04:05 AM |
