Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > General DIY Discussions > Wheels & Tires
Old 01-26-2015, 08:53 PM   #1
Legend of 94
Legendary Member
Legend of 94's Avatar
Legend of 94 is on a distinguished road
Default to roll my rear fenders or not to roll my fenders that is the question....
What up legend fam. I was recently gifted some 20 inch wheels and I'm running into a problem with my rear fenders rubbing the tires slightly. I've since done some research and it seems like most everyone has gone with rolling the fenders but I am unsure if that is the best course of action to take. I only need about 1/2 to clear the tires and don't want to try a different wheel size since the ones I have were a gift but I don't want to do anything stupid with my car either. Any thoughts????
Legend of 94 is offline   Reply With Quote
Old 01-27-2015, 05:04 PM   #2
I'm in the aftermath of rolled rear fenderwells on 2 of my cars now, both have chipped/rusted areas because the paint cracked off after being flexed. If you roll them at least get someone to put some good caulk, sealer and paint on the areas that get folded under.
Old 01-27-2015, 06:10 PM   #3
Legend of 94
Legendary Member
Yeah that was something I was definitely looking into doing but the thing is I've seen on here that rolling the rear fenders can be difficult so I was wondering since I need about a 1/2 inch should I look into maybe cutting them and finding after market fenders to slap on??
__Legend of 94__
Old 01-28-2015, 08:48 AM   #4
stella
SIX SPD
stella's Avatar
Real Name: Jeff Plunk
stella is on a distinguished road
I had the inner lip cut. Didn't want to fuk up my paint. Much safer way to go.
stella is offline   Reply With Quote
Old 01-28-2015, 09:06 AM   #5
Anytime you do any cutting or rolling of the fender, you should be treating it. Ideally that inner lip should be cut out otherwise it rolls under and acts like a rain gutter for water and road debris/grime.
Rich is right, you should be using some type of paint or caulk inside that lip if you dont cut it out, even if you cut it, it needs to be treated otherwise it will rust, and lets face it, any Jap car built in this time era has rust issues eventually, so proper car and preventative care is needed.
As far as drop in fenders, sadly they dont make any that just drop in, it would require custom modding an existing set, or custom modding your fender.
Old 01-28-2015, 01:52 PM   #6
Legend of 94
Legendary Member
Ok sounds good I'm thinking about going with cutting the lip then pulling the fender so I can totally clear my tires with of course doing a seal treatment. Any suggestions on what tool to use for the cutting job??
__Legend of 94__
Old 01-28-2015, 02:03 PM   #7
Legend of 94
Legendary Member
I'm considering just using a grinder
__Legend of 94__
Old 01-28-2015, 05:59 PM   #8
See what a local small body shop will charge to do the cut job. They might be able to do it cheaper then the damage you could cause with a grinder would cost.
Just a thought.
Old 01-28-2015, 06:20 PM   #9
Legend of 94
Legendary Member
Just a thought.
Yeah that could be a good idea. Especially since I'm kinda unsure about the cutting part. I just wanna get all of my options on the table before I go all out
__Legend of 94__
Old 01-28-2015, 07:56 PM   #10
Legend of 94
Legendary Member
With more thought honestly I'm starting not to like the cutting method just because a possible sharp edge around my tires scares me haha sticking with rolling only might cost me a 1/8 inch but the peace of mind goes way farther.
__Legend of 94__
Rear fenders(dog legs) kestans 2nd Gen. Legend General Discussion 3 11-22-2013 05:48 PM
Both rear windows won't roll up suddenly FutureX 2001 2nd Gen. Legend General Discussion 8 04-25-2013 06:50 PM
rear window won't roll up mxsloan 1st Gen. Legend General Discussion 10 04-16-2011 08:01 AM
Driver side window doesn't roll up/roll down in auto mode eugene 2nd Gen. Legend General Discussion 47 01-22-2011 04:35 PM
where buy wheel arch rear fenders? BrndaCZE 2nd Gen. Legend General Discussion 2 03-11-2010 11:08 AM
