#11 | ||
To loosen pre tension, jack up the rear wheels, loosen the bolt for the rear lower control arm where it secures to the rear sub frame cradle, just loosen the bolt, do not remove the bolt. Also do not confuse this with the trailing arm for rear toe adjustment. Once loose allow a few minutes for the shocks and springs to unload, I like to wait 20-30 minutes after Ive jousted the top of the tire a couple times to force the shock and spring downward. Once the suspension is unloaded tighten the bolt. Spec is like 40 ft lbs, I usually tighten them as tight as I can by hand and then give them 1 quick 1 second burst with my 1/2" impact. Like I mentioned earlier, with age these chassis are fatigued and have a good deal of flex to them that they didn't have 20-25 years ago, specifically the front upper strut towers, rear upper strut towers and the rear sub frame cradle. It would be wise to add tie bars to help reduce this flex and sag, ESPECIALLY if lowered, but will benefit even those that sit at stock ride height. A rear sway bar like the Addco (if you can find one) will also help reduce any sag. A lot of people think of the steering improvements with tie bars and sway bars, but forget about the most important factor, the increased rigidity and reinforcement sway bars and tie bars give the chassis. It's also worth asking what stiffness the rear struts are set at on the koni's. I would recommend full stiff or 1 click off full stiff in the rear, on softer settings the koni's do tend to have more travel in the dampener which could also be whats causing the rub. When I was lowered I ran k sports on full stiff in rear, so my suspension hardly moved
#12 | |
I'm about as low as a Legend can get now and have replaced the suspension components a few times now. As stated old worn suspension components just cause us more reasons to need maintenance as well as a lot of thinking/rethinking (praying pondering and hoping) on wheels and tire choices BEFORE we pull the trigger on getting them.
The Mad Scientist!! ![]() |
#13 |
Is He Ill?
IMO TL A-specs at 18" look to big on the Legends. They stick out from the fenders at 45 offset. Only seen a few individuals on here that did them well with lowered and slight negative camber in on em.
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Thread Tools | |
| Display Modes | |
| WTT: My 17" Aftermarket wheels for OEM 17" Acura Wheels | Hockeyman | Non-OEM Parts | 2 | 07-15-2013 08:59 PM |
| Legend GS rims/wheels vs. 04 TL Type S rims/wheels | LegenDinTheMaKing | 2nd Gen. Legend Performance Enhancements | 26 | 03-14-2011 02:07 AM |
| GS wheels | dwiz3443 | Wheels & Tires | 2 | 11-03-2009 12:12 PM |
| FS: Carlsson Wheels = GS Wheels? | lady6spd | "Not Mine" | 10 | 10-22-2009 02:09 PM |
