Guys,
New member here. I have a stock 1995 Acura Legend sedan (L) I found a set of "old school" mesh, staggered EWING rims with the following stats: front: 16x7 + 50 rear: 16x8 + 50 The bolt pattern is 5x114.3 and the center bore is 73mm. My first concern is with the rear width of the rim (8) as it seems that suggested width should not exceed 7 or 7.5. My second concern is the offset of +50 as OEM offset is + 65. I don't want to make any mods to the clearance, so I wonder if +50 will clear the brake caliper and will also not affect the backspacing. Any suggestions or insights are greatly appreciated! Thank you! Looking forward to your replies. |
Well sir the rear wheel is a little on the wide side but I think you'll be okay due to the high offset.
The Mad Scientist!! ![]() |
Thank you for the info. You're absolutely right about 8 being a bit wider than recommended. I think I'm going to pass on these wheels just as a precaution and keep looking for yet another set within a 7 mark.
Thanks! |
Tags |
offset, rims, wheels, width |
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
FS: New 19" wheels +48 offset - $449 Shipped! | LegendGS | Non-OEM Parts | 3 | 08-31-2015 07:46 PM |
Thoughts on changing offset on OEM wheels | stella | Wheels & Tires | 1 | 05-31-2013 03:02 PM |
Lowest offset + widest wheels? | ThrillSeeker | Wheels & Tires | 10 | 02-21-2012 10:21 PM |
Width and offset for a g2 help | bboarder711 | Wheels & Tires | 11 | 01-20-2012 03:21 PM |
another wheels offset ? H&R | Classico | 2nd Gen. Legend General Discussion | 4 | 01-28-2010 11:07 PM |
