09-06-2014, 08:30 PM | #1 |
Real Name: Ryan
Changing transmission fluid ?
So I've had my Rl for a little over a year and been wanting to do a transmission fluid flush. I had the car up on ramps and was looking for the plug to drain the fluid. I was looking towards the passenger side like I had read on a post from here, and theres a bolt that is hollow in the middle where you would put a 3/8 drive. but right next to this bolt is a label that days Diff fluid. So just wondering if I'm missing something here or is this this the right drain plug?
09-07-2014, 12:36 PM | #2 |
Real Name: Ryan
Anyone??
09-07-2014, 04:25 PM | #3 |
Real Name: Mark
The 3/8 drive one is the tranny drain. The diff plug is the differential. It takes 80/90 gear oil. Two entirely different services.
09-07-2014, 05:50 PM | #4 |
Real Name: Ryan
Ok I understand that. It was just a little confusing because right next to the 3/8 drive one it says diff fluid, so just wanted to make sure I had that straightened out before I change the fluid this week.
09-11-2014, 11:25 PM | #5 |
I forgot which bolt, but I did changed out the trans fluid a few months ago. I'll double check with the manual for you. My car never have the differential fluid change, would it be a good idea to change it now? The car has 196k. Thx.
Acura RL TYPE SLOW On A-93 BC coilover. |
07-12-2015, 08:56 AM | #6 |
Real Name: Bill Thomas
If changing trans fluid, double change it. I have G1 which takes 3 1/2 qts. Drive it a little after first change than change. This was instruction from service dept at Acura Dealer in \
Bedford, Oh. I have 272,000 and have never had tranny problem. |
07-13-2015, 08:07 PM | #7 |
♡ l4zy415 & Fut ♡
I'm not sure how you're seeing the differential drain plug where the transmission should be...
What year is your RL |
DIY: G1: Manual Transmission Fluid Change | sam o nela | First Generation Legend (1986 - 1990) | 10 | 07-31-2013 05:28 PM |
ATF-Z1 vs ATF DW1 -- Changing transmission fluid | R_R4 | 1st Gen. RL General Discussion | 13 | 03-15-2011 08:52 PM |
transmission fluid!!!! | 93-ka7 | 2nd Gen. Legend General Discussion | 4 | 05-24-2010 12:21 AM |
my first time i need help on changing my tranny fluid! | legend559 | 2nd Gen. Legend General Discussion | 5 | 01-31-2010 09:50 PM |
DIY: Manual Transmission Fluid Change | sam o nela | Second Generation Legend (1991 - 1995) | 0 | 06-10-2009 10:45 PM |
