03-05-2017, 03:22 PM | #31 |
Driver's side lower ball joint squeak got louder, so I spent yesterday replacing it. The axle was seized in the hub. After spending a couple hours trying to remove the axle, I rented the OEM 27037 axle puller from Autozone; three loud pops later and it was out.
I thought changing the ball joints on the Legend was challenging because of the angle created by the knuckle for using a ball joint press (OEM 27023)...the RL was worse. I ended up grinding off the ball joint stud and hitting the remnant with a 3lb. sledge hammer to get the removal started. An air hammer finished the removal. I was able to use the press in combination with the cap from the Honda adapter kit (OEM 27164) to press in the new ball joint most of the way then I beat on the top of the ball joint with a 2lb brass hammer to fully seat it. Not fun, but the junk car sounding squeak is gone.
My 1999 Acura RL "Build": http://forums.acuralegend.org/showthread.php?t=34510 |
03-22-2017, 12:44 PM | #32 |
Road Trip King
Wow, I'm just now seeing this thread but I'm very impressed with your level of care and detail throughout the process. That car has really taken on a new life thanks to you. Keep up the great work.
04-05-2017, 12:02 PM | #33 |
Thanks
Thread Tools | |
Display Modes | |
Bought a G1! | DevanTheDude | 1st Gen. Legend General Discussion | 32 | 08-25-2010 07:37 PM |
look what i just bought | OLDSKOOLACURA | The Water Cooler | 28 | 04-03-2010 05:29 PM |
has anyone ever bought from? | Biggg72 | The Water Cooler | 3 | 03-09-2010 07:55 AM |
Has anyone ever bought from here? | Biggg72 | 2nd Gen. Legend General Discussion | 16 | 01-11-2010 12:42 AM |
