08-29-2011, 08:38 AM | #61 | |
Btw not trying to discredit you, just trying to get the right info out there. I found the thread here: http://forums.acuralegend.org/suspension-t16998p2.html, but there has also been some on .com that I participated in also. Read post #20 (a response to a post I made) right after a post you made. Last edited by Espada; 08-29-2011 at 08:55 AM. |
09-04-2011, 04:08 PM | #62 |
ANTI CORPORATE
strong interest in these if produced, someone please contact me.
09-04-2011, 05:02 PM | #63 | ||
I think you are correct. It's the brackets in front of the LCA bushings that has been changed from 94-95 because of the different motor mounts.
03-14-2012, 11:02 PM | #64 |
Getting It Done
Did anyone's poly filled radius bushing last or rather how long?
When I was doing research a few months ago for these mounts I found a company that would take the stock ones burn out the old rubber, mold and heat treat in new poly in whatever grade you wanted. It was around $250 for a pair but I can't find where I put the damn info. hgeez:
hard work + dedication = perseverance Last edited by like no other; 03-14-2012 at 11:50 PM. |
03-15-2012, 07:40 PM | #65 |
Getting It Done
So I guess I can take it that anyone with poly fill radius mounts lasted a while
hard work + dedication = perseverance |
03-15-2012, 07:47 PM | #66 |
I did mine, it lasts but u gotta make sure u do it right or it will fuck up. I did one side twice because it would pop out
PM BOX IS FULL! Text me 724-584-0340 7/28/10 7:37pm Hell has frozen over Greek REMOVED his engine 1/26/13 7:23pm SHE RUNS! video >>> http://www.youtube.com/watch?v=Se4r5Y3RjqA 5/18/13 3:27pm DYNO! 577whp/501wtq @19psi |
12-11-2012, 12:26 PM | #67 |
Ive Got 2nd Gear!!!!
Real Name: Jonathan Roose
Success!!! hyundai sonata bushings installed. Now just gotta modify a lil more and were golden
It's not Gold, It's Cashmere |
12-11-2012, 12:59 PM | #68 |
Whats the part number and what is needed in order to do this?
12-12-2012, 05:23 PM | #69 |
Real Name: Sam
Those are the Hyundai bushings that have been mentioned in several threads, they run around $24/each. The outer diameter of them need to be shaved a few tenths of a millimeter in order to fit into the housing on the Legend bracket. Jon, I would love some full details, please! The machine shop said they could get it done, but it would cost me around $350 for the labor.
12-12-2012, 05:41 PM | #70 |
freeze the bushing and pop it in... thats what I heard he was gonna do.
Driver side upper Control arm | Roger | OEM Parts | 3 | 10-24-2009 01:13 PM |
Front Upper Arm torque specs | Roger | 2nd Gen. Legend General Discussion | 0 | 07-19-2009 07:47 AM |
Right upper A control arm | Roger | OEM Parts | 0 | 07-12-2009 09:17 AM |
New rear control arm creeking | Roger | 2nd Gen. Legend General Discussion | 0 | 06-29-2009 06:27 PM |
Rear control arm custom bushings | lgnd | 2nd Gen. Legend Performance Enhancements | 8 | 06-19-2009 11:52 AM |
