Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Second Generation RL (Fourth Generation Legend) -- 2005 - Present > 2nd Gen. RL Performance Enhancements
Old 05-17-2017, 07:21 AM   #1
jaconrad1
Real Name: Joseph
jaconrad1 is on a distinguished road
Default throttle body boring
Gents,
I was wondering what would be the recommended "boring out" of a type II throttle body, inner and outer bore? And is it advisable to have the neck of the intake manifold bored out as well, and if so to what size? Looking into having a local auto machine shop do the work for me. I know some of you have had this done, so looking for some guidance.
thanks
jaconrad1 is offline   Reply With Quote
Old 05-17-2017, 07:33 AM   #2
To answer your second question, yes. It should be bored to at least match your inner bore size
Sent from my SM-G920V using Tapatalk
Old 05-17-2017, 12:39 PM   #3
Even with over boring the throttle body and neck, you still have restriction in the intake manifold and heads, without addressing those as well, you're basically wasting money. Plus without opening up the exhaust side to help pull clean air into the cylinders, it won't yield much gain at all. You'll basically create a bottle neck at the intake runner and your fuel compensation values (long term and short term fuel trims) won't be able to adjust correctly.
Throttle body and body base. Sovereign 2nd Gen. Legend Performance Enhancements 21 06-22-2015 07:04 AM
throttle body legend91 2nd Gen. Legend General Discussion 0 03-26-2015 06:53 AM
Throttle body help Krizno 2nd Gen. Legend General Discussion 2 07-15-2012 02:38 PM
Throttle Body Boring njdixon4 1st Gen. Legend Performance Enhancements 8 04-08-2012 05:23 PM
Throttle Body Golden_Boy 2nd Gen. Legend General Discussion 2 07-16-2010 10:01 PM
