#31 | |
Real Name: A King!
The worst part of this job for me is getting those damn mid mounts back in and the transmission cable bolts back in. PITA!! |
#32 | |
Real Name: "Q"
"Out with the old and in with the new." 3.5 hybrid 5MT LS Check out my 4 sale thread:Click here!! |
#33 |
Real Name: A King!
Anybody know where all this oil residue could be coming from? It's right around the oil pump area and all over the differential and power steering bracket. Is there any seals anywhere around that area that I should change out?
#34 |
Super Duper Member
I would probably blame the vss seal and road grime. Does your car have a splash shield underneath? If anything, clean it up really good, and put a new O-ring on the vss assembly.
RIP Fut. ![]() 3.5 swaps, head gasket replacements, and 5/6 speed swaps done in less than a week. PM for a quote. |
#35 | |
Real Name: A King!
I have to get some more 3M High Power brake cleane. If anyone wants to clean their motor up really good? This shit works wonders!! Spray and watch the oil and grim wash away. You'll go through about 4-5 cans of it tho. I'm on my 3rd. Last edited by Aking; 05-14-2012 at 02:12 PM. |
#36 |
Real Name: A King!
She's almost all the why put back together. If im lucky I'll get her back in the car tonight.
Thanks again Walter for the knock sensors. ![]()
#37 | |
Ninjaneer
Build is looking good man!
http://forums.acuralegend.org/oil-le...light=oil+leak |
#38 |
Real Name: A King!
Not a whole lot of action last night, just went around the entire motor to make sure things were tightened down and everything is in place.
I did get my exhaust gaskets and exhaust manifold back on and my accessory belts on and tightened. Polyurethane casting compound (60A) is on order. I will be poly filling my motor mounts as soon as that arrives. Hopefully this Saturday I can get the motor back in the car. ![]() I also need to replace my VSS wire harness. |
#39 |
Real Name: A King!
Time to get those motor mounts poly filled.
Before: ![]() After (had a small leak thru the tape on one, should he ok tho):
#40 |
Real Name: A King!
All done!! Just took for a test drive. No more rear main seal leaks!!! Whoop whoop!!!
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Thread Tools | |
| Display Modes | |
| Pull Engine or Engine & Tranny?? | Aking | 2nd Gen. Legend General Discussion | 20 | 03-20-2012 03:37 PM |
| Tranny and Front Motor Mounts | Aking | OEM Parts | 6 | 08-01-2011 08:24 AM |
| Bolting Tranny to Motor | Aking | 2nd Gen. Legend General Discussion | 18 | 07-28-2011 07:58 PM |
| What does a Legend motor+ auto tranny weigh? | LegendLand | 2nd Gen. Legend General Discussion | 10 | 07-01-2010 05:32 PM |
| another 3.5 swap begins | 94T2 | 2nd Gen. Legend General Discussion | 14 | 06-13-2010 07:05 PM |
