Old 10-11-2021, 07:52 PM   #31
Swift
Winterhart MFG
Swift's Avatar
It has the two rough spots. Will be looking it over some more and then one last time in Spring before I pull everything. When you put balance belt on an it makes it worse(and I verified clocking position) doesn't bode well.
C35 H.O. build #2
Swift is offline   Reply With Quote
Old 12-27-2023, 08:19 PM   #32
Joe E
Formerly TypeRKon
Real Name: Joe E
Joe E is on a distinguished road
Any updates?
1994 - Acura Legend Coupe X 2
1995 - Acura Legend Coupe
2015 - BMW M3 [600whp] SOLD 2023
2023 - Roush F-150 SC
Joe E is offline   Reply With Quote
Old 02-02-2024, 08:44 PM   #33
Swift
Winterhart MFG
Swift's Avatar
Car runs. But need to pull transmission back off to get aluminum flywheel balanced.
Pulled borrowed Stromung B-pipe and type 2 muffler to bring to a place to make a few custom setups for guys to buy in Spring.
I installed a car hoist but concrete guy lied to me and ended up doing it myself and had to let it all cure.
I had an O2 sensor code because a wire pulled out of the loom area at ABS area.
However I am still knocking at 3k above and a little worried I have a lifter issue on passenger side cylinder head. I detuned back to Type 1 ignition and fuel basically and can tell I lost alot of power down low and STILL through a knock code!
Also, like most, life gets in the way and trying to pace myself and where I put my money.
In my neck of the woods I can't start work on it again until end of March at earliest , most likely May. This means prototyping parts on it as well.
C35 H.O. build #2
Old 02-04-2024, 06:57 AM   #34
It’s been awhile since I’ve been on here. I just finished reading your thread and wow, I know exactly how you feel especially when you said when things go wrong you don’t get mad just sad aka depressed. I also installed a 2post lift in my garage and love it. I couldn’t trust the contractor so I ended up doing it myself by installing the footings and electrical. I admire your drive and I hope you accomplish your goal with the coupe. Too bad we aren’t neighbors because the weekends would definitely be fun lol.
Old 02-05-2024, 05:53 PM   #35
Swift
Winterhart MFG
Swift's Avatar
Thanks man! Appreciate the support. Us legend owners can get over that girl that treats us so bad at times..
C35 H.O. build #2
Old 02-12-2024, 12:09 PM   #36
AMEN Brutha!!
Old 10-07-2025, 09:19 AM   #37
Swift
Winterhart MFG
Swift's Avatar
Bumpity bump bump!
So the 3.5 hybrid is back together after some work. I personally made new small end bushing to hone out properly for the new piston pins so less cold start clatter. The entire rotating assembly was balanced by me within a gram(f1 territory) and then brought with flywheel to have the crank balanced to the new weights. I then went to the work to back track(so much bs) to install the type 2 manifold versus keeping the much cleaner and elegant 3.5 layout. They type 2 intake proved to improve horsepower on most of the curve with Kenso and another individual so I felt I might as well. I then had to modify the one header to fit better.
I then had RL camshaft reground(not by WEB) to Type 2 specs with only 1 degree added duration, otherwise I would need to hardweld or use the rare Type 2 cams which I wasn't ready to sacrifice yet or reduce base circle to much.
On startup I worked through some issues, stupid vacuum lines, and potentially a sticking fast idle valve, but it still will not run good enough. I have ordered a AEM FPR because I believe I am running to lean and even with different chips and even a fully stock Type 2 ecu it is running to rough. This is with a new fuel filter and cleaned injectors. Also I threw in some well used NGK platinums because I didn't trust my iridiums even though they were a colder heat range for my added compression. I also swapped in some used o2 sensors because I think i was using RL sensors and didn't know if there was a difference to just make sure my ecu saw the correct readings.
. I am trying to be a little more transparent before the full reveal and just wanted to announce that it is back together. I probably will not get it running good till spring due to temperatures rapidly falling in MN.
C35 H.O. build #2
Old 10-08-2025, 09:09 AM   #38
3.5 swap, 5spd, custom, supercharged, turbo
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Anyone getting paid from youtube/adsense? GreekPower The Water Cooler 6 08-14-2011 01:15 PM
BEHOLD!!! The rebirth, the inspiration....the dream! emaculate94GS Second Gen Legend Gallery -- 1991 - 1995 32 07-23-2009 06:48 AM
Paid Accounts? Nine Four One Feedback and Requests 2 07-11-2009 05:39 AM
Inspiration at its finest Dance4Zak The Water Cooler 0 07-08-2009 03:30 PM
