Old 05-29-2025, 06:48 AM   #1
hJohn
hJohn is on a distinguished road
Default No color markings on crankshaft pulley
My G1 Legend jumped timing, I just checked the cams position through the inspection hole and none of the markings on the crankshaft pulley line up.
The problem I?m having now is that the manual refers to a white mark on the pulley for when you time it. My pulley has five notches, three grouped together, one close by those three and the last one is far away from the others. What color are they supposed to be? And which one is used for timing?
hJohn is offline   Reply With Quote
Old 05-29-2025, 10:20 AM   #2
Hi hJohn,
I'm not sure about the crankshaft pulley, but if you remove it & the lower timing belt cover, you can see a dimple on the timing belt pulley to use for alignment.
Can't get this crankshaft pulley bolt off! 92coupeType2 2nd Gen. Legend General Discussion 69 02-23-2015 05:14 PM
crankshaft pulley broke mgrover1 2nd Gen. Legend General Discussion 26 03-12-2013 11:44 AM
crankshaft pulley reena OEM Parts 4 06-06-2012 11:10 AM
Crankshaft Pulley Crimson Night 2nd Gen. Legend General Discussion 9 01-15-2011 12:30 PM
Crankshaft pulley holder Dubs94leg 2nd Gen. Legend General Discussion 5 10-06-2009 11:17 PM
