07-27-2021, 04:07 PM | #11 |
is building things
question 1) Can this be compensated by milling passenger side bank x amount you think?
2) Do you know by how much you were able to compensate? And that was just on the passenger side cam...or was that on both cams on the exhaust side? I know of Andrews, probably pointed you in the direction. Since these are new cam cores, they could grind based on your info to get at least close, I could degree them in a block and let them know by how much to address. This could all be done in a cnc program nowadays i think.
C35 H.O. build #2 |
07-27-2021, 08:03 PM | #12 |
You cannot compensate. It IS four different lobe designs. You need to get the paper,do the measurements and have Andrews design the lobes. Anything else is fantasy.
#1 in Honda C32A engines worldwide. The innovators, not the imitators. |
07-27-2021, 08:10 PM | #13 |
And I wouldn't go chasing too much power. At 780hp @ 14.5 PSI boost I can't keep the heads clamped on. Head gasket failure at 63 miles distance in competition use. The main caps are chafing on the block with total run distance from new of 90 miles combined testing and competition.
07-27-2021, 09:13 PM | #14 |
As the cam base circle gets smaller it changes the angle of the rocker. You must maintain the specified/Honda oem base circle diameter. There are no shortcuts here.
I suggest you talk to Andrews, weld up two lobes on each cam and start from there. That way if there are problems you can weld again to maintain the design base circle. Did I mention there are no shortcuts here?.
#1 in Honda C32A engines worldwide. The innovators, not the imitators. Last edited by buzzard; 07-28-2021 at 06:04 AM. |
07-28-2021, 05:25 PM | #15 |
is building things
My confusion lies in the fact you have always said it was due to timing...because of the belt and decking the heads makes it worse. Since these will be NEW camshafts I would of course have him maintain the oem base circle since that is kinda the whole point. Others can get drastic grinds, i am just doing a performance cam for the C35 and then a slightly better camshaft just about a type 2 for the C32.
C35 H.O. build #2 |
07-28-2021, 09:18 PM | #16 | |
PM BOX IS FULL! Text me 724-584-0340 7/28/10 7:37pm Hell has frozen over Greek REMOVED his engine 1/26/13 7:23pm SHE RUNS! video >>> http://www.youtube.com/watch?v=Se4r5Y3RjqA 5/18/13 3:27pm DYNO! 577whp/501wtq @19psi |
07-29-2021, 02:24 AM | #17 | |
However, due to the contact point between the rocker "shoe" that slides on the cam being different from one bank to the other, you need to design the lobe to suit the rockers. Please have a look at the contact point between the rocker "shoe" on one bank and the other at the start of the intake lift. Completely different, and thus effectively a different ratio rocker.The lobe is designed so as to give equal lift and timing on both banks. If you do not accept what I say (and I have no problems with that), have a set of cams reground with identical lobes for both banks, fit to the engine and measure. You can test this very easily without a degree wheel. On one cam pulley make a mark exactly 180 degrees from the factory timing mark (count the teeth). Put the engine on TDC. Remove timing belt. Rotate crank about 60 degrees (this will move the piston away from the valves) Rotate cam 180 degrees, align new mark Rotate crank back to TDC and refit belt. You will now notice that intake valves on CYL 1 and 5 open together. Fit dial indicators on cyl's 1 and 5 to measure valve lift. Rotate engine and observe how closely the dial indicators track each other. In my experience the indicators will track within 0.002" of an inch of each other with standard Honda cams fitted and all parts in good condition. I have reground cams here where the error exceeds 0.100" lift bank to bank. You will either need solid lifters or welded hydraulics to stop the stock lifters collapsing under the valve spring load. Below is the email I received from John Andrews in 2007 Hello Chris: I am attaching two PDF documents to this email. They both have basically the same information. Our experience with OHC oscillating follower type cam systems is that: 1. They are very difficult and confusing to everyone who works with them. 2. Without an engine setup and degree wheel placed next to a cam grinding machine, getting the desired final cam design and timing output will be very time consuming and expensive. Let us know after you have reviewed the attachments. John Andrews Products The reason for this is not only do you have to design the lobes correctly to suit the rockers, you also have to get the lobe centers correct. This is a complex system and there are no shortcuts. The cam timing can be measured very easily once you are setup to do it. I have an engine setup in the corner of the engine room specifically for measuring cams.
#1 in Honda C32A engines worldwide. The innovators, not the imitators. Last edited by buzzard; 07-29-2021 at 03:52 AM. |
07-29-2021, 02:27 AM | #18 | |
Car is fitted with an Albins AGB gearbox with torque converter.
07-29-2021, 02:38 AM | #19 |
https://www.youtube.com/watch?v=-nyHBick22U
3:30 you will hear the Honda doing it easy. Shame about the music
07-29-2021, 02:45 AM | #20 |
Tags |
camshaft, camshafts, regrinds, webcams |
Non- performance threads in performance section | Legend37 | Feedback and Requests | 11 | 10-27-2021 11:17 AM |
2021 NALM Phoenix AZ Registration & Hotel Information | Tyson | NALM | 82 | 10-14-2021 07:56 AM |
2021 check-in! | TALRUDE | The Water Cooler | 60 | 08-27-2021 09:24 PM |
2021 Florida New Years Meet | Alperovich | Meet Photos | 1 | 01-10-2021 10:45 PM |
Announcement: NALM 2020 Postponed to Fall 2021 | Tyson | NALM | 8 | 07-04-2020 04:03 AM |
