11-24-2016, 10:17 PM | #81 |
The type 2 springs if i recall are a swap into the RL heads.
The type 2 valves work aswell, but they need a valve job on the heads to fit (you would do this anyways to properly seat them). As for upgrading springs you can use comp cams springs part number 937-16 for the upgraded supertech valves, I have the last 2 sets because I paid the patent fee and had 50 intake/50 exhaust valves made. It was 1100 for a full set but till this monday I have them at 1000 bucks shipped just because I want to get the money back in my hands. just incase seraph orion confused you on the valves, those are J series valves on supertech's site, not the proper C series valves.
PM BOX IS FULL! Text me 724-584-0340 7/28/10 7:37pm Hell has frozen over Greek REMOVED his engine 1/26/13 7:23pm SHE RUNS! video >>> http://www.youtube.com/watch?v=Se4r5Y3RjqA 5/18/13 3:27pm DYNO! 577whp/501wtq @19psi |
11-26-2016, 03:08 AM | #82 |
Thanks guys! I appreciate the help
12-25-2016, 10:56 PM | #83 |
Novice
@Lou, I said u can but the springs on comp cam. I neversaid u nor the website was selling super tech springs.
02-17-2017, 09:14 AM | #84 |
casatirider
Lady tries 3.5 swap
Guys, I was successful in swapping the 3.2 for a 3.5 and the car running. I did not swap the ECU was that mandatory?
02-17-2017, 09:58 AM | #85 |
No you keep using the 3.2 ECU. RLs (3.5s) have a different system that isn't compliant with Legends. Now if only you could get a "tuned" chip for your 3.5. I hear in dark corners of the community those (tuned/chipped ECUs) may yet again become a possibility.
The Mad Scientist!! |
02-17-2017, 11:40 AM | #86 |
a tuned ecu is the key.... also jon hughes read this... lets swap it!
How does the Type II ECU run a 3.5 hybrid? | soloist | 2nd Gen. Legend Performance Enhancements | 4 | 10-10-2012 07:57 PM |
Type II heads and cams for 3.5 hybrid swap | tubadude | OEM Parts | 5 | 04-19-2011 10:42 AM |
So it begins, another 3.5 hybrid Type II swap | soloist | Legend Builds | 184 | 12-26-2009 12:18 PM |
'95 3.2/3.5 hybrid swap mount | Jonslegend | OEM Parts | 16 | 08-18-2009 04:46 AM |
