03-25-2010, 04:25 PM | #1 |
Pulling Codes (CEL/ABS/TCS/D4/DPMS)
And finally, the first WikiDIY thread is here, the first of what will hopefully be many new DIYs. This was written specifically for the wiki to work out a clean format and layout for future WikiDIYs. It is a topic that has a few other guides already, but none of them as comprehensive as this one.
LegendWiki - G2: DIY: Diagnosis: Pulling Codes If you have any updates/changes/suggestions, you are all free to modify it as you wish. If you are unfamiliar with wikicode, you can also post your comments here, where someone else can incorporate your ideas. Last edited by Quaraxkad; 03-25-2010 at 09:16 PM. |
03-26-2010, 01:35 AM | #2 | |
Just wanted to mention that. |
03-26-2010, 04:24 AM | #3 |
03-26-2010, 07:41 AM | #4 |
ignore the smoke
'92 Electrical Troubleshooting Manual agrees, page edited .
Sig by Cole Austin RIP Fut RIP l4zy Stop by the unofficial Acura Legend IRC channel: Rizon #acuralegend.org Check out the Acura Legend Wiki! |
03-26-2010, 11:59 AM | #5 | ||
03-26-2010, 01:28 PM | #6 |
Well Wisher
awesome Q, keep up the good work!
'94 GS 6MT KA7 Sig by DG |
06-28-2011, 12:34 PM | #7 |
Legend Loyalty
Real Name: Lucciano
On my way home to check this out...I just wanna make sure its the vss i really need. Im tired of putting cash in wrong places.
02-16-2016, 09:09 PM | #8 |
Quick video: how to read your diagnostic codes
Hey guys, today I pulled some codes from my 1993 Acura Legend using a paper clip.
A year ago my cars D4 light started flashing. So I took it to Sears to read the code, but since is older than 1996, they "don't have the code readers" and referred someone else. The mechanic wanted me to make a future appointment at a cost of $100. I already figured the VSS was bad, and would rather replace the $150 part, than pay $100 for being positive. Today I finally decided to try pulling the codes myself. I didn't realize how easy it was. The check engine light was a 17 and the D4 was a 4. Both refer to the VSS. hahah I was right! I made a video to help anyone who's more visual and Quaraxkad kindly added it to the bottom of this page: http://www.acuralegendwiki.org/index..._Pulling_Codes Video link: https://youtu.be/7EvSLydt4pQ Thanks for the awesome wiki! Take care, Pandja Here's the codes: http://www.acuralegendwiki.org/index...nd_Definitions Last edited by pandja; 02-16-2016 at 09:11 PM. |
02-17-2016, 10:16 AM | #9 |
Great video!:b owdown:
When the snow ends in the Snowbelt and my snowball comes out from under its' blankets I'm gonna get my paperclip!!!!!!!!!!!! |
10-03-2016, 01:02 AM | #10 |
To pull codes use the bobby pin located under the dash just a blue 2 pin connector put the bobby pin into the connector that look at the check engine light I flash long means 10 and regular flashes means 1 so let's say you get 1 long flash and 3 regular flashes means code 13....
ABS/TCS Issue | Losaun | 2nd Gen. Legend General Discussion | 17 | 05-13-2010 07:49 PM |
Need help on codes...cel/abs/tcs | (=^.^=) | 1st Gen. RL General Discussion | 18 | 03-12-2010 08:23 AM |
Pulling Check engine light (CEL) codes | Aking | 2nd Gen. Legend General Discussion | 11 | 01-31-2010 08:10 AM |
Pulling ABS codes | GreekPower | 2nd Gen. Legend General Discussion | 21 | 07-08-2009 05:10 PM |
