Old 07-03-2012, 05:59 AM   #1
93-ka7
93-ka7 is on a distinguished road
Default thermostat housing
Does anyone have a diy for replacing the thermostat housing?? I want replace that specific part brand new??..
93-ka7 is offline   Reply With Quote
Old 07-03-2012, 06:18 AM   #2
It's only 2 bolts. Might ad well swap the thermostat while you have it open.
Old 07-03-2012, 07:02 AM   #3
Mike Diaz
Super Duper Member
Mike Diaz's Avatar
Mike Diaz will become famous soon enoughMike Diaz will become famous soon enough
3 bolts including the ground that's attached to it. I use a 1/4" 10mm socket and a 3" extension to remove the housing bolts.
RIP Fut.
3.5 swaps, head gasket replacements, and 5/6 speed swaps done in less than a week. PM for a quote.
Mike Diaz is offline   Reply With Quote
Old 07-03-2012, 10:28 AM   #4
Mikey
Canadian Rust
Mikey's Avatar
Mikey is on a distinguished road
I had to do mine, the O-ring was shot. Had to remove the intake manifold, followed the headgasket DIY. Did a whole bunch of stuff while I was at it.
MagicMikey
1991 Acura Legend LS Sedan
Granada Black
Mikey is offline   Reply With Quote
Old 07-03-2012, 10:32 AM   #5
93-ka7
Im refering to the other part of the thermostat housing the one that sits by the intake manifold
Old 07-03-2012, 10:49 AM   #6
Team LR
UndaUGal
Team LR's Avatar
Team LR is on a distinguished road
It's 2 12mm bolt holding the housing to the water pump
Team LR is offline   Reply With Quote
DIY: Speedometer Housing Replacement sam o nela First Generation Legend (1986 - 1990) 1 04-05-2014 07:37 PM
How the heck do you remove the thermostat housing? GS_Legend 2nd Gen. Legend General Discussion 21 11-06-2010 09:15 PM
Coolant leak from thermostat housing Mikey 2nd Gen. Legend General Discussion 26 03-16-2010 06:37 PM
JDM/USDM Reflector Housing Question holyabish1 2nd Gen. Legend General Discussion 2 03-04-2010 04:39 PM
