06-05-2017, 07:35 PM | #1 |
boring cylinder heads
I was wondering if anyone has had their cylinder heads bored out? If so what did you have them bored too? Pistons? ect... very curious if this has been done.
thanks |
06-06-2017, 09:46 AM | #2 |
There's nothing to bore on the heads except the valve seats and if you are going to start messing with changing the valve size you need to do your research on calculating the right size based on changes you make to cams, intake, psi, exhaust and cylinder bore.
The information is readily available to a resourceful googler and it's all math. I'm not going to take the time to dig up my own research since doing the work yourself is very important to taking on a job like that. rich
06-06-2017, 09:50 AM | #3 |
yes its been done, but unless you plan on investing actual money into the motor don't bother.
I have custom valves, springs, ported heads, pistons, rods, etc all in a 3.5 just buy it and save yourself a ton of headaches
PM BOX IS FULL! Text me 724-584-0340 7/28/10 7:37pm Hell has frozen over Greek REMOVED his engine 1/26/13 7:23pm SHE RUNS! video >>> http://www.youtube.com/watch?v=Se4r5Y3RjqA 5/18/13 3:27pm DYNO! 577whp/501wtq @19psi |
07-26-2017, 10:01 PM | #4 |
Formerly TypeRKon
Real Name: Joe E
3.2 > 3.5
My block was bored and sleeved. I have forged pistons by CP and forged rods.
1994 - Acura Legend Coupe X 2 1995 - Acura Legend Coupe 2015 - BMW M3 [600whp] SOLD 2023 2023 - Roush F-150 SC |
tl-s hub boring | IamPlan_B | Wheels & Tires | 5 | 10-11-2015 03:09 PM |
Widened T2 manifolds and the use of T2 cylinder heads on 3.5 | soloist | 2nd Gen. Legend Performance Enhancements | 11 | 03-30-2012 12:16 AM |
Removing cylinder heads. Need help | bbjornson | 2nd Gen. Legend General Discussion | 12 | 02-28-2011 11:54 AM |
Clutch master cylinder and slave cylinder | Stillmatic | OEM Parts | 1 | 11-29-2010 02:51 PM |
'89 rebuild cylinder heads for $200... | pnoye2 | 1st Gen. Legend General Discussion | 15 | 07-16-2009 09:18 PM |
