01-01-2010, 10:54 AM | #1 |
MeltingInTheSun
O2 Sensor Replacement
Just changed the two O2 sensors and thought someone else might need a reference. Tools required: 1. O2 Sensor socket 2. 18" extension 3. 2-3" extension 4. big long breaker bar (I had to use pipe as extension) 5. 10 & 12mm sockets/wrenches to remove other stuff Drivers Side is pretty straight forward: 1. Unplug O2 sensor at front of valve cover 2. Put O2 sensor socket on sensor 3. Take 18" plus 2" extensions and "thread" from behind brake fluid reservoir and attach to O2 sensor socket. 4. Add the breaker bar and pipe extension and break the sensor loose (only break it loose with the socket). Use your hands to unscrew, you can also just turn the wire harness and it will come undone on its own. 5. Reverse the order to install. (I used NTK 24172 sensors from NGK, they are direct fit so no wires to play with.) Passenger side takes a bit more work: 1. Remove black box by EGR valve 2. Remove 3 wire harness connectors by black box (harness clipped to heat shield) 3. Remove main wire harness connector at rear of valve cover 4. Remove heat shield (3 10mm bolts, the top 2 are not bad the 3rd one is hard as it is at the bottom below the A/C line and hard to reach). The heat shield will come out toward the front of the engine. 5. Now attach the O2 sensor socket to the O2 sensor 6. "Thread" the long extensions through the vacuum lines and then carefully using the breaker bar with extension break the sensor loose. Again remove by hand twisting the O2 sensor wire harness will make it easier. 7. Reverse the order to install. I got my new OEM type O2 sensors from www.sparkplugs.com ** Notes: The O2 sensors can be really hard to get off and sometimes the O2 sensor sockets don't want to do the trick. This can usually be taken care of by cutting the wires and using a deep "normal" socket, however this means you will HAVE to get it out as there is no going back!!
Parting out 4 91 L Sedans (mostly type 'F', some type 'E') and 93 Coupe type 'E': https://docs.google.com/spreadsheets...it?usp=sharing Last edited by ari_one; 01-02-2010 at 09:16 AM. |
01-01-2010, 11:34 AM | #2 |
DEUS EX MACHINA
That would be me... Thankyou... Have this thread subscribed.
01-02-2010, 01:49 AM | #3 |
A quality sensor socket is a must, I've snapped the cheap ones on the sensor before. Nice DIY
01-22-2010, 01:23 PM | #4 |
Real Name: A King!
what kind of O2 Sensors do you recommend we put on? I did not know they were over $100 a piece.
01-22-2010, 01:38 PM | #5 |
My Penis Has A Name
thanks for the site link! every automotive shop I've been to has said the Bosch sensors are over $200 a piece. These prices seem very fair! I'll be ordering me up a couple next pay check along with some iridium NGK's
Repping you now
-Some things never change, and some things do- |
01-22-2010, 01:39 PM | #6 |
Even seeing how cramped it is...if its any consolation this is much easier than on the G1!
Great job Ari! |
01-22-2010, 04:32 PM | #7 | |
03-21-2013, 04:46 PM | #8 |
6 speed baby!
Are the O2 sensors the same on both sides as far as part #?
03-21-2013, 05:13 PM | #9 |
Virginian
Real Name: Dan
Rock auto has the denso o2 sensors to my door for both less than 100. Plug and play. No splicing
No one is longer than the other. |
03-21-2013, 05:15 PM | #10 |
Virginian
Real Name: Dan
DIY: DIY: G2 ABS Code Retrieval & Sensor Replacement | GrtOutdoorsAZ | Second Generation Legend (1991 - 1995) | 18 | 11-22-2009 03:18 PM |
Replacement Oxygen Sensor | huckleberry | 1st Gen. Legend General Discussion | 9 | 10-26-2009 05:22 PM |
FS: knock sensor(s) | alittlethin | OEM Parts | 3 | 10-14-2009 01:10 PM |
For those in need of even ONE oxygen sensor... | sam o nela | 1st Gen. Legend General Discussion | 12 | 07-09-2009 05:35 PM |
DIY: Crank Angle Sensor (Code 4) Replacement...No Pics | sam o nela | First Generation Legend (1986 - 1990) | 0 | 06-03-2009 12:26 PM |
