09-19-2021, 06:06 PM | #91 |
is building things
Someone posted this before....I forgot...and it led to a lot of cussing.
The EBAY ones need to be countersinked WAY deeper to match that of the OEM style. The angle is also not a typical countersink you would find at home depot. I would have to measure, but I believe it is a 72 degree...not 90 or 82.
C35 H.O. build #2 |
09-20-2021, 12:27 PM | #92 |
Here is a link that might have the right chamfer.
https://www.ebay.com/itm/29402846004...53.m1438.l2649
1995 Acura Legend LS Coupe 6spd. JDM TYPE II, 6spd trans (lower mileage). 5-spd flywheel, EXEDY clutch. Fut MLS strut bar, H&R springs,Monroe shocks,ADDCO Front & Rear sway bars, FUT Tie Bars,SPC ball joints, MOOG Front Upper control arm anchor bolts, EBC ULTIMAX Rotors f+r,AKEBONO ceramic pads f+r. Poly mounts(60a). BLACKEND damper.18x8 40 offset KONIG Verdict. BF GOODRICH G-Force T/A KDW. |
09-22-2021, 04:32 AM | #93 | ||
I have purchased both of the linked bushing types. I have not yet installed either of them, but as far as perceived quality I do prefer one over the other. Below are each of the recently mentioned links and my thoughts.
Ebay : mount_expert: Quote:
Ebay : best4autoparts1 Quote:
As with all things Ebay YMMV, but as a person who has both sets sitting on the shelf I can testify one (best4autoparts1) vendor appears to be offering a better product at a cheaper price rich
10-11-2021, 06:49 PM | #94 |
is building things
I will buy another set of the "good ones" to compare and take some measurements as well.
Thanks for the info Rich!
C35 H.O. build #2 |
Driver side upper Control arm | Roger | OEM Parts | 3 | 10-24-2009 01:13 PM |
Front Upper Arm torque specs | Roger | 2nd Gen. Legend General Discussion | 0 | 07-19-2009 07:47 AM |
Right upper A control arm | Roger | OEM Parts | 0 | 07-12-2009 09:17 AM |
New rear control arm creeking | Roger | 2nd Gen. Legend General Discussion | 0 | 06-29-2009 06:27 PM |
Rear control arm custom bushings | lgnd | 2nd Gen. Legend Performance Enhancements | 8 | 06-19-2009 11:52 AM |
