G1 Driver
Does anyone know how these are attached? Are they just glued in place? I don't see any way that they would be bolted on.
1990 Legend L Sedan, was Auto, now 5 spd mostly Bahama Gold Metallic; 391k miles 1990 Legend L Sedan, Auto Olympia White; 200k miles |
They actually do bolt onto the car. through the trunk lid. There are studs that go through pre-marked spaces on the trunk lid (will need to remove the liner to see those drill hole locations) and there is a specific nut for those studs that hopefully you'll receive/retrieve along with the spoiler itself. I do know for the G2 EDM spoiler that is similar to the G1 spoiler that the fuel rail cover nuts are the same thread as the bolts to the spoiler. I hope for you if you do NOT have the nuts that those mentioned above have the same thread pattern for the G1 spoiler studs. I actually have pictures of the G2 EDM spoiler original nuts as well as my "fix" using the fuel rail cover nuts. I do believe the nuts that go with the spoiler may be ever so slightly longer.
The Mad Scientist!! ![]() |
G1 Driver
Good to know. Thanks. If I find a trunk with the spoiler, I'll just take the whole trunk lid then.
I can't say I blame you on that one.
I've been tacitly looking for a 1994 Sirius White Pearl Sedan trunk lid WITHOUT a wing that hasn't had the VULTURES destroy the lock or trunklid all together trying to open it without the key. Simple trick is to plug in the battery to ones drill using two wire pieces to the trunk pop button plug (or have a spare plug with exposed wire ends) while in the salvage yard and TAH DAH "Open Sesame" (says a me )! I've come across that scenario a few times.
The Mad Scientist!! ![]() Last edited by 94LegendaryAcuraGS; 01-23-2025 at 12:24 PM. |
| Thread Tools | |
| Display Modes | |
| DIY: Load Resistor Installation for Factory Spoiler | byalegend | 2nd Gen. Legend General Discussion | 3 | 07-04-2014 02:09 PM |
| WTB: black 94-95 sedan trunk with spoiler | Dreams94coupe | OEM Parts | 5 | 11-22-2013 05:29 PM |
| trunk spoiler | Willie t | OEM Parts | 1 | 05-05-2013 08:03 PM |
| '99 3.5 RL trunk spoiler? | daveCFPrez | 1st Gen. RL General Discussion | 10 | 08-31-2012 10:28 AM |
| Jdm g1 trunk lip spoiler | samo8ty5 | OEM Parts | 4 | 11-01-2009 12:29 AM |
