07-30-2011, 01:22 PM | #1 |
Real Name: A King!
Tranny and Front Motor Mounts
Need some tranny and front motor mounts. If anyone has some, let me know.
07-30-2011, 01:40 PM | #2 | |
Need to know what year. 91-93 mounts are different than the 94-95 mounts.
07-30-2011, 02:41 PM | #3 |
Real Name: A King!
Sorry, need mounts for 95.
07-30-2011, 02:49 PM | #4 |
A pound of poly from mcmaster.com runs around 40 bucks and will do 4 - 6 mounts easily. Go to the casting compounds and You will throw a lot away doing your mounts but it's still cheaper than 2 front mounts.
60A is about as solid as you would want to go on those front motor mounts, it will be fine for your transmission mount. I did my buddies 95 coupe trans mount and he has no vibration. I did not do the front motor mounts though. rich
08-01-2011, 07:45 AM | #5 |
Real Name: A King!
DIY said 1 tube of compound will work but I dont see where you can order a tube. Lots like you have to order it by the lb.
08-01-2011, 08:07 AM | #6 |
The "tube" is probably in reference to Window Weld. McMasters casting compound is highly preferable over that stuff.
08-01-2011, 08:24 AM | #7 |
Real Name: A King!
Yea, I'm just going to order a lb of the 60A poly urethane. Its $33 bucks which is way cheaper than buying new mounts.
need used motor mounts..asap..! | mochudley | 2nd Gen. Legend General Discussion | 8 | 06-04-2010 07:23 PM |
Need motor mounts!!! | dmendez7 | 2nd Gen. Legend Performance Enhancements | 3 | 07-16-2009 12:21 PM |
Motor Mounts? | OregonWineBaby | 1st Gen. Legend General Discussion | 16 | 06-25-2009 07:55 PM |
motor mounts | AyeJay | OEM Parts | 9 | 06-09-2009 04:20 PM |
Motor Mounts. | Jonslegend | 2nd Gen. Legend General Discussion | 17 | 06-07-2009 01:14 PM |
