hey guys i thought i would make a diy today since i didnt see any for this on the site.
tools required: wire cutter soldering iron shrink wrap lighter/heat gun small flat screw driver (for glasses) flat screw driver and phillips screw driver lets starts with the edm switch to open up the edm switch use the glasses flat screw and gently pry on the tabs in the 4 yellow boxes to get off the 2 buttons. on the back use the switch use the screw driver to pry up the tabs to get off the back cover. ![]() hazard light switch take out the a/c controls and unplug all the connectors the connector for the harzard switch plug is what will be using use a glasses screw driver and pop open the connector and pry out all the pins. BE VERY CAREFUL because you dont want to break it. now push the wires into connector so that it lines up with the pins below (dont push in all the way. always double check prior to pushing in the pin all the way) ![]() hazard switch is in yellow pin 1 is of no use so just bend it downward pin 2 goes to blue/yellow pin 3 goes to white pin 4 goes to blue/green pin 5 goes to red pin 6 goes to red/black this is pic of the connector after i switched the wires around ![]() Foglight switch is in red pin 1 is for ground pin 2 is for the park light dimmer bulb (splice into pin 6 wire from hazard switch) pin 3 is for the park light dimmer bulb (splice into pin 5 wire from harzard switch) pin 4 is for the trigger wire. this normally is spliced into the park light blub pin 5 is for the trigger wire that goes to the relay since my switch didnt come with a plug i had to make my own. i soldered each wire to the pin and then used shrink wrap to protect the connetors. i purchased a connector from radioshack and soldered the wires to pins. ![]() how is looks when all wired up ![]() usdm courtesy/fog/tcs switch on the connector the last three slots on the far left should be open use pins: put the relay trigger wire into the far left connector put the park light trigger wire into the middle connector put the ground wire in the right wire ![]() as for wiring up the lights you would do it either your fog lights or jdm headlights but that should pretty much be straight forward. if you have any questions or things to add feel free to do so. Dream
hmm i guess it wasnt good enough for diy section.... epic fail
hgeez:
good job man!
Not forgotten.
Excellent DIY post. I'm sure this answered someone's question and will be a resource in the future
#5 |
Go, Green Ranger GO!
Real Name: Me
LOL nah i'm moving it now. Was gonna let it get some burn here, so people could comment and know that theres a DIY for it now. Alot of people don't constantly visit the DIY section to see what's new.
[SR5guy Stage III ECU | Cold Air Intake | Remus Exhaust | Fut
MLS Copy Strut Bar][6000k TSX projector retrofit | 6000k Hella Micro DE foglights] |
thanks for the replay guys and thank you banana for moving it.... i always wanted to be in the DIY section.... yes i know i need a life but Legend IS MY LIFE!!!
#7 |
L.A.麺部 is JDM LEGEND
Great job! Can we please see the finished product.
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| Thread Tools | |
| Display Modes | |
| Home made FOGlight bracket | Legend95 | 2nd Gen. Legend General Discussion | 14 | 09-08-2009 02:40 AM |
| FS: 91 Coupe Foglight covers | The Crowing | OEM Parts | 8 | 08-20-2009 04:07 PM |
| OEM Foglight Questions / Install Problem | FutureX 2001 | 2nd Gen. Legend General Discussion | 20 | 08-18-2009 09:10 PM |
| Made the Switch | DJBacon06 | New Member Introductions | 16 | 08-10-2009 06:58 PM |
| Made the switch | Kasper | New Member Introductions | 4 | 06-09-2009 12:44 PM |
