Old 06-17-2009, 07:22 PM   #1
Wayne-A-Ferd
The Slow Cruiser
Wayne-A-Ferd's Avatar
Real Name: Wayne
Question I Need Help.. Steering Tilt
k, for some weird reason, the tilt on my car dosen't work... anyone might know how to fix it? i can't pull my cluster without breaking it lol... please help and thnks in advance
Old 06-17-2009, 07:50 PM   #2
antik
I blame the M3.
antik's Avatar
What do you mean by doesn't work? If you push the buttons nothing happens or it doesn't deploy to its memory position correctly when you put the key in the ignition?
Are your memory seat lights blinking? If so, this solidifies the likelihood of the following working:
Pull the [only] 7.5A fuse in the under-dash fuse panel for 30s or so. Put it back in and see if things work better.
'95 Auto L Sedan [SOLD]
Old 06-17-2009, 07:52 PM   #3
stella
SIX SPD
stella's Avatar
Real Name: Jeff Plunk
stella is on a distinguished road
If you have a 93, i dont think you have tilt. only manual in and out.
stella is offline   Reply With Quote
Old 06-18-2009, 06:49 AM   #4
Wayne-A-Ferd
The Slow Cruiser
Real Name: Wayne
i'll take a pic in a little bit and show what i mean lol
Old 06-19-2009, 12:58 PM   #5
Alladin
Laos
Alladin's Avatar
Alladin is on a distinguished road
If it doesn't work with the fuse, remove the battery cable (+ or -) and let sit for about 5 minutes. reconnect the battery cable and you should be good to go... If not you will probably need a new switch... (make sure you have your radio code before temporary removing the battery cable).
Alladin is offline   Reply With Quote
Old 06-19-2009, 01:06 PM   #6
Wayne-A-Ferd
The Slow Cruiser
Real Name: Wayne
man i hope that works lmao it's raing right now so i don't wanna open my hood... i'll try and let yuh know thanks you guys
steering tilt
