09-15-2012, 09:58 AM | #21 |
What a great project! Good luck with it. Body matching engine bay color is a big + in my opinion.
09-15-2012, 10:19 AM | #22 |
Lord Of The Clunker
Real Name: Ze Orderly?
If it makes you feel better, you can't drain it at the cooler lines. You can get some fluid out through them, but no matter what there will still be several quarts in there.
Here is a tip I've repeatedly learned (sometimes I have to fail things multiple times before it sinks in...) When you go to put the trans pan back on, get a can of THE RIGHT STUFF gasket maker and use it instead of the crappy rubber gasket that comes with a filter kit. Those things ALWAYS leak around the trans pan curve. And why did you bother unbolting the entire hubs?! |
09-15-2012, 10:38 AM | #23 | |||
Because the axles come out through the knuckle, the only other way is to unhook the lower balljoint to swing the knuckle out the way. That risks damaging the balljoint boot, which is cheap, but the 4 bolts holding the hub to the knuckle were ridiculously easy to remove despite their locations, and that was free. Free is cheaper than cheap.
Stop by the LegendWiki! 1994 Acura Legend LS 1992 Cutlass Supreme S (Supercharged swap complete!) Need ground wires? "Big 3"? Battery relocation? Amplifier power? Last edited by Quaraxkad; 09-15-2012 at 10:40 AM. Reason: Grammar Nazi. |
09-16-2012, 02:56 PM | #24 | |
Lord Of The Clunker
09-16-2012, 04:27 PM | #25 | |
Having never removed this engine before, I got lucky and didn't have to go back in and disconnect anything. It came right out the top with no drama or snags. The engine bay is quite a mess. Next I'll start cleaning that up. Then I'll make my final decision on the engine bay color. I'm leaning towards "rattle-can" high-temp gloss black right now rather than the potential future exterior color, primarily for budget reasons. I still haven't even bought the replacement engine! My running total for this build is currently at about $80... For the leveler and some bolts to connect it to the engine brackets, a T60 socket, bigger pry bars, and a fuel line disconnect tool. The foam and rubber insulation that runs along the whole firewall is trashed. I pulled it off and it crumbles into pieces. I don't know if this stuff is just for sound suppression or if it's a heat shield. If it's just for sound, I don't care about it. But if it's supposed to reduce heat in the cabin I'll probably want to do something about replacing it. Here it is around the C100 connector, where a huge chunk broke off: I have two wiring harnesses on the firewall that I want to get out of the way. One of them is screwed in from inside the cabin, probably in a difficult to reach location but I haven't looked inside yet. The other is underneath the brake booster, and had two bolts on it which I removed, but it still appears to be attached. Tomorrow I will begin with the heavy-duty cleaning, and then paint.
Stop by the LegendWiki! 1994 Acura Legend LS 1992 Cutlass Supreme S (Supercharged swap complete!) Need ground wires? "Big 3"? Battery relocation? Amplifier power? Last edited by Quaraxkad; 09-16-2012 at 06:06 PM. |
09-19-2012, 08:30 AM | #26 |
Ive Got 2nd Gear!!!!
Real Name: Jonathan Roose
Watcha doin with them there gs's sir
It's not Gold, It's Cashmere |
09-19-2012, 08:42 AM | #27 |
They're sittin' on a shelf. Ran across them at the junkyard on a Legend year/model on which they didn't belong, all in good shape but dirty. Couldn't pass up the opportunity so I bought them. I had to build my shelves *around* the spare wheels...
09-19-2012, 09:19 AM | #28 |
Well Wisher
Phew that's a Lotta work! Gl with your project
'94 GS 6MT KA7 Sig by DG |
09-19-2012, 01:52 PM | #29 |
Okay golden star for me. It looks like a pretty in depth project. Have fun and we'll keep watching your progress. Going to do a custom ground wire kit for it?
The Mad Scientist!! |
09-19-2012, 02:01 PM | #30 |
Wow, good job on removing the engine. When i saw the car on your first post, i was like, "Meh, i don't like the body style". Can't wait to see it finished man.
My Build Thread Oh my gawd That jar better blow me twice and cook breakfast for $1000. |
Quaraxkad's problem... | rwheadon | The Water Cooler | 25 | 12-30-2011 07:50 PM |
