Old 09-03-2009, 06:47 PM   #1
94legendcpe
Junior Cheeseburger
94legendcpe's Avatar
94legendcpe will become famous soon enough
Default Anyone know how to drop the steering column?
Not having any luck in finding a how to in the service manual or on here. Anyone have any pics or description of how to drop the column?
94legendcpe is offline   Reply With Quote
Old 09-03-2009, 07:12 PM   #2
Ken
ridin' high
Ken's Avatar
Send a message via AIM to Ken
remove drivers side under dash cover. extend the steering wheel all the way out. There are two 14 mm nuts right where the dash meets the steering column. remove those. then trace the steering shaft and you will see two 14 mm bolts with a U clamp thing. unbolt that and you're done. Be sure to support the column when you unbolt it or else it'll drop on you.
its either 12 mm or 14mm, im pretty sure its 14mm though.
. k e n
Old 09-03-2009, 08:11 PM   #3
whats77inaname
Not forgotten.
whats77inaname's Avatar
When you take out the first 2 14s mentioned above, be ready, b/c 1) the column is heavy and 2) it's coming down *lol*
Old 09-03-2009, 09:53 PM   #4
94legendcpe
Junior Cheeseburger
Thanks for the heads up guys, was worried I was going to eff something up. As usual, the forum rocks!
Old 09-04-2009, 12:34 AM   #5
eugene
Luxurious Coupe
eugene's Avatar
eugene is on a distinguished road
Are these instructions just for dropping the steering column or maybe lowering it a little as well? I mean I'd love if my steering wheel was a little lower that it is right now. But column seems to move in and out only.
So is there any room to play around with the height of the column or none?
Thanks!
eugene is offline   Reply With Quote
power steering oops.. GreekPower 2nd Gen. Legend Performance Enhancements 8 08-08-2009 08:55 AM
Steering issue Apex|000 2nd Gen. Legend General Discussion 7 07-29-2009 01:57 AM
I Need Help.. Steering Tilt Wayne-A-Ferd 2nd Gen. Legend General Discussion 5 06-19-2009 01:06 PM
Last post column smokinfastlegend Feedback and Requests 2 06-08-2009 08:53 PM
