Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > First Generation RL (Third Generation Legend) -- 1996 - 2004 > 1st Gen. RL General Discussion
Old 09-24-2009, 10:22 PM   #1
brysta
Default Steering column issue
hey I have a question- my steering column stopped going up and down, it will only go in and out. the problem is it is stuck up real high, and that sucks.
Anybody have this prob before?
brysta is offline   Reply With Quote
Old 09-24-2009, 10:43 PM   #2
sometimes u can pull the fuse and it'll start working again, sometimes it'll stop after a little bit again. mine was doing this then finally quit working all together.
Old 09-25-2009, 03:30 PM   #3
seamusnh
seamusnh is on a distinguished road
The RL's had a problem with the small electric motors fail. I've heard of this on some forums...
seamusnh is offline   Reply With Quote
Old 09-29-2009, 12:52 PM   #4
aftermathacura
aftermathacura's Avatar
aftermathacura will become famous soon enough
the plastic gear that turns the motor for it is most likely broken. honda and their damn plastic!! if this is the case you can adjust it with a flathead screw driver to atleast get it back to the postion were you normally drive. there is no part available to fix this. honda only sells the entire steering column. check the list price on #3.
http://acuraautomotiveparts.org/acur...s=&view=normal
would it have been so hard to just use metal to metal for the gears.hgeez:
''the ka9 is my weapon of choice in this legend game''
aftermathacura is offline   Reply With Quote
Old 09-30-2009, 01:17 PM   #5
lgnd
EDM KA8 owner
lgnd's Avatar
Real Name: Istvan
lgnd is on a distinguished road
same with the jdm folding mirror motors. small worn out plastic gearings.
lgnd is offline   Reply With Quote
Old 10-01-2009, 07:34 AM   #6
brysta
that's hilarious! almost $1900? ha! fat chance!
well, thankfully, it came on the other day and moved, so I think it is the switch or a short or something.
Old 10-02-2009, 12:30 PM   #7
seamusnh
You can count the plastic pulley in the window regulators as another poor design choice. I had heard of the steering wheel motor problem before and tried to remove the motors from my RL before it went to the crusher but they were buried in the guts of the steering column....
Old 01-19-2010, 04:15 PM   #8
meandino
meandino is on a distinguished road
Whats the fuse to do this?
meandino is offline   Reply With Quote
Clicking in sterring column 90LSCoupe 1st Gen. Legend General Discussion 17 09-09-2009 11:09 AM
Anyone know how to drop the steering column? 94legendcpe 2nd Gen. Legend General Discussion 4 09-04-2009 12:34 AM
Steering issue Apex|000 2nd Gen. Legend General Discussion 7 07-29-2009 01:57 AM
Last post column smokinfastlegend Feedback and Requests 2 06-08-2009 08:53 PM
