Old 05-21-2019, 10:17 AM   #1
jgoeke
Real Name: joe goeke
jgoeke is on a distinguished road
Default Best way to pull a 3.2 V6 engine
Hey all, i'm new to the list and to the Acura Legend cars. I actually have a 1998 TL 3.2 but best i can tell that is just later version of the Legend (longitudinal mounted motor). Anyway i'm looking to pull and replace the motor for it appears to be seized (cannot turn crank with car in neutral, timing belt off, overhead cams turn fine).
So i'm looking for any instructions on how to pull the motor. I see three ways:
1) Pull motor
2) Pull motor with transmission
3) Drop motor/trans in subframe
I have a lift and engine hoist so i can do it any of the ways, but not clear on which way is best for a new person to this car. I've done a few engine/transmission replacements but still kind of new to it all.
I did find a old link to removing engine and transmission, but sadly it is not active best i can tell and only view-able as a cashed page and only page 1 at that. Here is the link
http://forums.acuralegend.org/engine...ion-t7612.html
Anyway, i would love any suggestions and or other links to info or videos on how best to do this.
Thanks in advance!
jgoeke is offline   Reply With Quote
Old 05-21-2019, 03:17 PM   #2
I'm guessing you already know this, but the motors are in different directions from Legend to TL.....
Old 05-21-2019, 03:40 PM   #3
Don't forget to pull the spark plugs before you try to turn the crank, in case there's fluid in a cylinder that has it hydro-locked.
Old 05-21-2019, 04:07 PM   #4
Why is this general question in the galleries section?
Old 05-21-2019, 04:20 PM   #5
jgoeke
Well the 96 to 98 3.2 TL is a longitudinal mounted engine, and that is like the Legend right?
Old 05-21-2019, 04:21 PM   #6
jgoeke
my bad, i'm new. for some reason i thought i was in the right place....
Old 05-21-2019, 04:22 PM   #7
jgoeke
yes, plugs are out, and they were gone well before i got the car. One if the issues i suspect is rust from them being left out....
Old 05-21-2019, 04:32 PM   #8
It's a nitpick, but an important one... the TL is not a "later" Legend. The later Legend is the RL.
That said...
For both G1 and G2 Legends I always have pulled the engine and transmission together out the top. Actually every engine I have ever pulled came out the top. I didn't figure out what I felt was a safe drop out of the bottom without rigging some sort of cradle to set it into. Jonslegend and SR5guy dropped them out the bottom all the time.
Coming out the top you will need a good balancer, a friend to keep the thing from banging into engine compartment stuff is always useful.
Old 05-21-2019, 09:50 PM   #9
jgoeke
That said...
Thanks, yes, i'm a nube ;-) Just trying to find usefull info on this car which has turned out hard to find. thanks for the info.
Old 05-24-2019, 05:51 AM   #10
I did not realize that the 1st. Gen TL has a longitudinal engine. I’m guessing the 2nd gen has a sideways engine?
Engine pull Alperovich Legend Builds 93 02-18-2014 01:45 PM
Pull Engine or Engine & Tranny?? Aking 2nd Gen. Legend General Discussion 20 03-20-2012 02:37 PM
Super Cool Engine Pull Pics and Vids!! (56k You Crazy!) Reboticon 2nd Gen. Legend General Discussion 21 07-24-2010 02:06 PM
U-Pull it A** F*** alittlethin The Water Cooler 21 06-04-2010 11:56 AM
What tools needed to pull a junkyard engine? LegendNoob 1st Gen. Legend General Discussion 18 04-10-2010 08:50 PM
