Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Second Generation RL (Fourth Generation Legend) -- 2005 - Present > 2nd Gen. RL General Discussion
Old 09-18-2012, 05:35 AM   #1
tstint16
tstint16's Avatar
Real Name: Thomas Stinson
tstint16 is on a distinguished road
Question Left Rear Brake Light
Im having an issue that I hope this community can help me with. I notice my rear tail lights not working so I checked all the fuses, checked the relay. I even changed out the entire left brake light unit. Park lights still not working, when I step on the brakes everything works fine turn signal works, brake light works just not the tail lights or some may say parking lights. I need help? p.s. The right rear works perfect.
tstint16 is offline   Reply With Quote
Old 08-29-2014, 10:07 AM   #2
metpage
Real Name: Billy
metpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant futuremetpage has a brilliant future
Originally Posted by Cody Brown View Post
Tell him to make sure that his calipers aren't frozen when installing new pads or rotors, better yet replace them or rebuild them if in doubt. This will help to insure longer life and no rotor warping. I've had mine on a Honda Element for a year and been happy with them.
Luk Schaffer
makes a nice slotted cross drilled rotor (this may help keep them cool and prohibit warping) for not a ton of money. I think they're called Black XD Series.
What does that have to do with brake lights? Rotors/pads/calipers don't affect the cars tail lights.
Sent from my Nexus 4 using Tapatalk
metpage is offline   Reply With Quote
Old 08-29-2014, 10:09 AM   #3
metpage
Real Name: Billy
Did you check to make sure the bulbs aren't blown? If I remember all the bulbs in the tail lights are the same. Try swapping them with known working bulbs and see if they light up.
Rear brake light modular tstint16 OEM Parts 1 09-17-2012 06:39 AM
FS: used OEM front brake pads 80-90% left bsmooth1027 OEM Parts 0 04-18-2012 07:52 PM
FS: G2 Coupe rear deck trim with 3rd brake light KA-Chow! OEM Parts 0 04-26-2010 08:39 AM
Brake hose : Left and Right different???? LV_legend_2 2nd Gen. Legend General Discussion 3 11-13-2009 08:50 PM
