Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Gallery > Videos
Old 08-01-2009, 08:20 PM   #1
Default 8.1.09 dyno run.
Old 08-02-2009, 03:37 PM   #2
Russian
Russian's Avatar
Russian will become famous soon enough
You need a 5spd flywheel.
Russian is offline   Reply With Quote
Old 08-02-2009, 03:41 PM   #3
91ls 3.5
I'm coming!!
91ls 3.5's Avatar
91ls 3.5 will become famous soon enough
Isn't this the motor swift built ya??? Numbers r still fairly low for the mods you have done to it....Time to go 3.5 man
Mi dey yah
91ls 3.5 is offline   Reply With Quote
Old 08-02-2009, 03:54 PM   #4
no i built the motor. swift help me assemble and drop it in. i did do the work, well the stuff not done by the machine shop
Old 08-02-2009, 04:10 PM   #5
91ls 3.5
I'm coming!!
91ls 3.5's Avatar
Still kinda low numbers...Def. need a 5speed flywheel and clutch...3.5 in ur future?
Edit: Limme clarify myself, because right now I myself think I sound like I'm thread crapping, what I meant to say is that those numbers are well on par for a STOcK typeII 6mt but your motor has mods, headers, exhaust, valve job etc... So I expected higher, correct me If I'm wrong.
Mi dey yah
Old 08-02-2009, 05:43 PM   #6
i think they are low too. i'm kinda disappointed atm. idk, highly considering swapping in the motor from misty right now. maybe winter project.
Old 08-02-2009, 05:50 PM   #7
Nino418
3.5 Hybrid Powered
Nino418's Avatar
Real Name: Ze Nurse
misty? alex are you nuts? stop being a B***H and get a 3.5 already. no matter what you do to a 3.2 it still wont be as good as a 3.5. and all those diehard 3.2 fans saying the 3.5 is a waste all have something in common:
1. they havent blown a headgaskit
2. they have never driven a 3.5
R.I.P
Old 08-02-2009, 05:50 PM   #8
sap
ignore the smoke
sap's Avatar
Send a message via AIM to sap
Unless you get something that points to the block or heads being (compression or leakdown results?) an issue I wouldn't go swapping engines quite yet.
Sig by Cole Austin
RIP Fut RIP l4zy
Old 08-02-2009, 05:54 PM   #9
Nino418
3.5 Hybrid Powered
Nino418's Avatar
Real Name: Ze Nurse
the 3.5 has a redesigned cooling system fyi. honda basicly said they had cooling system issues with the 3.2's and the flaws were changed in the 3.5 motors.
R.I.P
Old 08-02-2009, 07:00 PM   #10
91ls 3.5
I'm coming!!
91ls 3.5's Avatar
There's always a nay-sayer who makes judgements but have never even experienced the 3.5.
Mi dey yah
OFFICIAL 2ND GEN DYNO THREAD Dv8 2nd Gen. Legend Performance Enhancements 72 05-25-2023 06:25 AM
sap's Sedan Progress Thread (Run 56k, Run Screaming) sap Second Gen Legend Gallery -- 1991 - 1995 49 01-12-2017 11:42 AM
TELION VS. SR5GUY CHIP DYNO RESULTS! filmshoot 2nd Gen. Legend Performance Enhancements 161 12-15-2009 05:16 PM
butt dyno saying f---in WOOOOOOT!!! Alperovich 2nd Gen. Legend Performance Enhancements 24 07-01-2009 01:25 PM
Dyno Vid Nino418 Videos 9 06-05-2009 09:04 PM
