Old 04-01-2010, 08:44 AM   #71
Outlaw92
The Innovator
Outlaw92's Avatar
Real Name: Ray
Outlaw92 is on a distinguished road
Send a message via Yahoo to Outlaw92
Originally Posted by ari_one View Post
Gas evaporates very fast but a 1/4 tank is hard to believe.
Lets just say I fill it half-way. Then the next morning it would be slightly above the 1/4 mark.
When you go fill up at the gas station can you see any leaks??
I believe I did once. But then again it was raining also. Everytime I fill up I check and it does not drip.
Originally Posted by alittlethin View Post
I'm betting you have a hole in one of the rusted pieces of tubing. Crawl around with a pointy screw driver and poke and scrape at the lines (top of the fuel tank and going back to the fuel pump along the body)
I had a a rusted through line on my 1991. I replaced a piece of tubing going from the top of the fuel pump going down to the fuel rail running under the car. I replaced it with $2.00 (OEM is $160.00 or some ridiculous #) of 1/4" fuel hose at the hardware store and double SS clamps. Rubber fuel line is rated at 150 psi.
coolant leak / (do a cold pressure check on the system (20 psi) and you should fine the weak point)
P.S. If Ari has the line you could buy it from him. All of his parts are Arizona born and rust free.
Thanks for the info. It is nice outside today so I will be looking around for a lot of things.
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Outlaw92 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
FS: Cabin Air Filter $5 onthe3rdday OEM Parts 4 08-27-2009 08:05 PM
Location for running a wire into the cabin? FutureX 2001 2nd Gen. Legend General Discussion 16 08-21-2009 01:02 AM
Whats your cars smell? GreekPower The Water Cooler 51 08-18-2009 12:58 AM
Air Conditioning Bad Smell veee 1st Gen. Legend General Discussion 2 07-24-2009 08:39 AM
Gas smell under the hood when hot mad_legend 2nd Gen. Legend General Discussion 10 07-23-2009 01:09 PM
