Old 02-20-2010, 04:25 PM   #1
Gascan
Less doom less gloom
Gascan's Avatar
Real Name: Michael K.
Default 3.5 Dyno Problems
So I don't destroy the dyno thread, I've made a separate thread.
Something is not right with my car...
Best run:
197.07 HP
188.38 TQ
A 3.5 should not be this low. Reminds me of Jen's (=^.^=) 5 cylinder run.
I've been getting a fuel metering code off and on. I'm no expert but the Air/Fuel ratio shouldn't look like that.
Using new plugs, fuel filter and the injectors have recently been serviced by WitchHunter.
Type II intake/injectors/ECU
Intake
OBX Headers / redone Y-pipe
High-Flow Cat
Resonator
Magnaflow muffler
(it's an auto)
Old 02-20-2010, 04:43 PM   #2
MXHalofan
Type O Master
MXHalofan's Avatar
Jen has T2 cams. I bet that's where you're losing some power. Others can confirm or offer more insight.
Oh, you're auto. That thing is a power robbing fluid pump. I'd say those numbers look great for your setup.
91 Coupe LS black on black
GS wheels
MXHalofan is offline   Reply With Quote
Old 02-20-2010, 04:58 PM   #3
antik
I blame the M3.
antik's Avatar
MX has a point. Comparing your AT numbers to MT numbers is not an apples to apples comparison: you should be down on net power relative to a MT due to increased lost between the engine and wheels.
'95 Auto L Sedan [SOLD]
Old 02-20-2010, 05:21 PM   #4
Drivetrain loss ftmfl. They are correct, auto tranmissions lose much more power through the drivetrain than a manual trans will. Given your mods vs what other cars similar to yours have put down in a dyno, I'd say you are shooting par for the course.
Old 02-20-2010, 08:07 PM   #5
Dv8
Life Ruiner
Dv8's Avatar
First off, go back to the dyno and have them print off your graph again with SAE correction (top right).
Lets see the new numbers and go from there.
Whats up with the boost table? If theres no forced induction, that can be removed for a bigger graph. If you used a wideband, have that table made to display A/F
~Dv8
Best run:
197.07 HP
188.38 TQ
Intake
High-Flow Cat
Resonator
Magnaflow muffler
(it's an auto)
GT-R 3/7/15 9.2 @151MPH | 12/19/13 994whp 895wtq Dynojet 186 1/2 Mile
16 yrs and counting. To many Experts, not enough Results. Where are yours? Retired Legend 616WHP@18PSI 10/11 12.1@124MPH 02/12 N/A 234whp 229lb-ft 13.7@99mph 95 deg. 06/07 Lexus IS-F Nitrous 11.3@123MPH 392WHP 372WTQ I/H/E N/A-Ladies car now.
Go-Kart 35whp 29wlbft http://www.2slik4u.com/
My Garage
"People can always copy what I did first" -Jesse James
RIP Dannie FUT James
Dv8 is offline   Reply With Quote
Old 02-20-2010, 08:24 PM   #6
Like I said in the other thread. Maybe a better tune might help it out a bit. Check ur plugs.
But IMHO your numbers are spot on. I was just talkin about this with some else the other day. Look at the graph I posted of jen's car. Ur numbers look good. Get lighter pulleys that'll give you a few hp.
What ur gaining in the 3.5 is the power down low. Look at how much more tq u have vs a 3.2.
The problem with the 3.5 heads is they don't get enough air in them up top. :dunno:
Tom needs to dyno his car with the cams. Also I think shaving the head down as much ad possible is a must.
Old 02-20-2010, 11:07 PM   #7
soloist
OCD Legend member
soloist's Avatar
Real Name: Brandon S.
Isn't there another 10-15% drivetrain loss with auto's? (I'm asking because I wasn't sure what exactly the percentage of loss was)
Hmm...Type II manifold with bolt-on's for exhaust and intake, so you've got the potential to move a lot of air with a big restriction at the cams. Seems the dyno numbers for the 3.5 hybrid with a manual were, what, 228-230whp? Subtract the cams and loss from the auto, doesn't seem too bad.
Old 02-21-2010, 12:56 AM   #8
no, that's where your wrong, 3.5's putting down 228+ had webcams+head work done, and then it was at giving up some low end tq for high end hp but still had good tq numbers up high.
kenso put down 228 with his 3.2 with headwork+cams, but his tq numbers where lower. also i forget how much foreva, and godfather put down with their 3.2's.
cams are a problem but also the heads themselfs are a restriction also.
Old 02-21-2010, 01:42 AM   #9
soloist
OCD Legend member
soloist's Avatar
I see, thanks for the info
Old 02-21-2010, 01:44 AM   #10
I learned something today
Dyno Day Gascan Northwest US Region 55 08-17-2010 09:42 PM
My dyno uh oh... (=^.^=) Videos 26 12-21-2009 01:19 AM
Just got back from the dyno kcf 2nd Gen. Legend Performance Enhancements 58 12-12-2009 07:10 AM
8.1.09 dyno run. Alperovich Videos 24 08-20-2009 08:47 PM
Dyno Vid Nino418 Videos 9 06-05-2009 09:04 PM
