Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > First Generation RL (Third Generation Legend) -- 1996 - 2004 > 1st Gen. RL General Discussion
Old 10-15-2015, 06:14 PM   #31
pmendoza502
pmendoza502 is on a distinguished road
Lol, my in/out gears died a while ago, luckily when my up and down died recently it was in a good spot... Anyone follow up on that group buy, or possibly a group buy for Metal ones? Anyone try 3d printing them? Lol
Sent from my SM-N920P using Tapatalk
pmendoza502 is offline   Reply With Quote
Old 02-01-2016, 04:36 AM   #32
rawkluvah
rawkluvah is on a distinguished road
The most ridiculous thing happened to me with regards to the steering wheel tilt/telescope option. The "motor" seemed to have stopped working. I noticed when I started my car that the wheel didn't adjust. I took it to my local Acura dealer who quoted me $3500 to "replace the motor". I could barely keep a straight face. I left there so disappointed. Later I had gone into an appointment. When I came out to start it, the car battery was dead so I had to call AAA. Front to back they installed a new battery for me in less than an hour. As soon it was installed the mechanic asked me to get in and start it. When I stuck the key in the ignition, the steering wheel went both up and down then in and out. He explained to me that I had a dead cell in my battery and it obviously made a difference. What do you think I had to say when I went back to speak to the manager of the Acura dealer who had quoted me $3500 to fix it? I live on Maui and there is only one dealer here. Shipping anything here is a cost nightmare. Two years later it has stopped working. It's not likely a battery issue this time although there have been a few times when the overhead light in the car was left on overnight. UGH!! The reason I've shared this with all of you is, if there is only ONE frustrated Acura 3.5RL driver out there that has a battery problem they may not even be aware of yet, this could be your fix. It would make me so happy. In the meantime, I hope I don't have to ship a steering column across the ocean to have this option work on my car. I'm new. I hope I haven't broken any rules. I did read all of them. If I have I apologize. Let me know.....Aloha
Last edited by rawkluvah; 02-01-2016 at 04:54 AM. Reason: Added an apology if I broke any rules. It's my 1st post
rawkluvah is offline   Reply With Quote
Old 02-01-2016, 05:03 AM   #33
OLD_HATCH
OLD_HATCH is on a distinguished road
Yup can happen. That's why number "1" says to reset the module by either unplugging the battery or the module.
You always want to start simple before you go spending money.
OLD_HATCH is offline   Reply With Quote
Old 02-02-2016, 03:31 PM   #34
rawkluvah
Hatch, thank you for your quick response (and your tolerance of the newbie on my first post). I will of course give #1 a try. Such as my circumstances were with the first time this happened, a dead cell in my battery, I thought that it wouldn't be completely accurate but it certainly is where I should start...again, thanks. By the way, your car is a beauty!
Old 03-26-2017, 04:26 PM   #35
Dario
Dario is on a distinguished road
This might be an old thread but for those looking for an answer today. If you just want to move the steering wheel to a fix position. You can just remove the motor (the 4 phillip screws). Drop it down, remove the broken plastic gear (use a screw driver or anything, just digit out and then with a flat screw driver, turn the pivot where the plastic gear was. Put were you want it and you are done!
Dario is offline   Reply With Quote
Old 05-30-2017, 12:57 PM   #36
OLD_HATCH
That would leave the center shaft free to spin so eventually your steering wheel will fall down to its lowest position.
First post remains the most viable
Old 06-09-2017, 01:37 PM   #37
Slamman60
Slamman60 is on a distinguished road
It's 2017 and we are still having the same problem. How has a 3D printable file not became available?
Slamman60 is offline   Reply With Quote
Old 06-09-2017, 01:43 PM   #38
OLD_HATCH
Because it's not that simple. The original is a nylon gear molded on top of a steel shaft and then two steel ends pressed into the steel shaft.
I could "possibly" get a company to replicate but price would be astronomical. We would need one hell of a group buy to get decent prices.
Old 07-02-2023, 04:12 PM   #39
asrichardson
asrichardson is on a distinguished road
Originally Posted by HapaLegend View Post
Dennis.
Can you send me your broken gear? I'm tempted to draw it up in Solidworks and see who I can have make it for all us people with the broken column...
Any progress on creating that file in SolidWorks? I'm working with a junkyard set of gears, that are fully intact, but would like to create a machined aluminum billet option, that would never break. Am trying to scan with PolyCam at the moment, to see what can be determined. I have an '03 with 48K on it - trying to keep it in OEM condition.
asrichardson is offline   Reply With Quote
Steering column issue brysta 1st Gen. RL General Discussion 7 01-19-2010 03:15 PM
Tilt motors for steering column Biggg72 OEM Parts 4 11-12-2009 10:39 AM
Anyone know how to drop the steering column? 94legendcpe 2nd Gen. Legend General Discussion 4 09-03-2009 11:34 PM
I Need Help.. Steering Tilt Wayne-A-Ferd 2nd Gen. Legend General Discussion 5 06-19-2009 12:06 PM
DIY: Steering Slack Fix sam o nela First Generation Legend (1986 - 1990) 0 06-03-2009 10:49 AM
Copyright ©2000 - 2024, vBulletin Solutions Inc.
