Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > General DIY Discussions > Wheels & Tires
Old 08-20-2022, 01:54 AM   #1
stillak
stillak is on a distinguished road
Default 17x8.5 wheels with +38 offset
Hello,
I am wanting wheels which are 17x8.5 and only available with +38 offset.
I have a 91 coupe.
What are my options for getting them to fit in the fenders? I hate negative camber and still want meaty tires for ride quality.
stillak is offline   Reply With Quote
Old 08-22-2022, 10:48 AM   #2
Originally Posted by stillak View Post
Hello,
I have a 91 coupe.
You would have to roll the fenders pretty aggressively and those wheels are still likely to "poke out" from the fenders. I have a set of 17 X 7.5 with a +38 offset and they do fit in the rear of my rolled fender coupe but the fronts poke out just a little bit. I have a set of 18 X 8 wit a +38 offset to upgrade to and already know those are going to have a bit on the front sticking out and that may happen even if I go down to just a 215/40/18 tire like I have on my sedan verses the current 225 width tire I have on the coupe now. The front track of the car is a tad bit wider than the rear and those nice stock fender flares up front do a MARVELOUS job of fooling the brain into not noticing.
Old 08-25-2022, 02:44 AM   #3
stillak
so you're basically saying its achievable.
I plan to lower the car with H&R springs and roll the fenders as much as possible.
However, I'm not a fan of thin tires and negative camber.
PS. Can anyone share pictures of an 8.5" or 8" wheel with +38 offset?
Old 08-25-2022, 09:04 AM   #4
Hockeyman
Real Name: Blake
Hockeyman is on a distinguished road
Not sure if helpful, but i run 17x8 et44 up front and 17x9 et49 on my coupe. Pics on my IG ka8_blake
Hockeyman is offline   Reply With Quote
Old 08-28-2022, 10:29 PM   #5
stillak
Did you pull out the fenders/roll them? and how much was your car lowered? Is it H&R springs?
Old 08-29-2022, 07:24 AM   #6
Hockeyman
Real Name: Blake
fenders are stock, car is on bags
17x8 +35 offset... Francisco Wheels & Tires 3 01-24-2014 12:43 PM
FS: Work VS-SD 17x8 / 5x114.3 / +36 Offset Boondock Saint Non-OEM Parts 16 08-01-2010 09:17 PM
Will 17x8.5" w/65 offset fit on rear of G2 Coupe? MemberLS02 Wheels & Tires 8 12-13-2009 08:20 AM
FS: testing waters - 2005 TL 17x8 wheels with 235/45/17 Nexen 3000 tires kotetu OEM Parts 16 07-22-2009 12:00 PM
