#41 |
That's odd. Both of my dome lights turn on. Make sure the ground cable on it is secured and making good contact. Also make sure the LED bulb works too.
My Build Thread Oh my gawd That jar better blow me twice and cook breakfast for $1000. |
#42 | |
Peace Sells
![]() Quote:
I think the ground wire is fine cause the halogen lights up fine, after messing with it I gave up and didnt think about it again until I replaced the domes recently. Guess it will end up slipping my mind again until I sound deaden.
#43 | |
if you look at my first post with pics you should have all the leds needed for a sedan with memory front seat. i did not do a led change on any of the door lights or the dome but those are LED #3022. so u need 6 of those for 4 doors and 2 domes and if you want 7 (add one) if you want to make your trunk light a LED
(and the glove box has a 3022 bulb too if you wanna make that led too) ohh and add two 74 wedge types for the trash door lights in the rear doors of the sedan they have lights in them also. itinkso9 has a coupe so he got most of them on there correct for a coupe since they have less lights to change. by the way this would end up costings around 60 bucks or so depending on how many leds each bulb you buy has, and how many you want to change. you dont have to go with what i got on each one. but you do have to get the type of bulb. Like type 74 but you can use the cheap single type instead of the 3 led type like i use for some bulbs. Quote:
#44 |
Peace Sells
The ones I have are these:
http://www.superbrightleds.com/cgi-b...on_3022-xx.htm Both the 4 and 9, neither work in my rear dome. Cool white ( before they offered natural)
#45 |
Real Name: Peter
Wow, was digging for a thread like this for a while.
Real nice DIY too bad, the images are not available anymore. My recently bought G1 has no interior lights. Was wondering, searching but found no answer yet: What color is the originals dashboard/cluster lighting? Will try to go through this thread post by post to come up w a plan... From Europe will be a bit more challenging but I hope to find the parts easily. |
#46 |
Have you verified you have power to the light sockets?
-Kennon |
#47 |
Real Name: Peter
Thread Tools | |
Display Modes | |
led lights should they look like this | bsmooth1027 | Second Gen Legend Gallery -- 1991 - 1995 | 14 | 01-03-2010 11:27 PM |
HB3 LED | Legend95 | 2nd Gen. Legend General Discussion | 12 | 12-31-2009 12:52 PM |
LED Lights | 90LSCoupe | Group Buys | 68 | 12-23-2009 07:34 PM |
LED | 90LSCoupe | 1st Gen. Legend General Discussion | 54 | 10-11-2009 10:32 PM |
led signals | EvanSALegeng | 2nd Gen. Legend General Discussion | 11 | 08-16-2009 03:27 PM |
