01-09-2022, 09:36 PM | #1 |
1989 LS Coupe 5 Speed: CEL 12 problems
Hello, I'm new to this website and glad to have found it. I have a 1989 Legend Coupe with the 5 speed manual and really love it. Since I have had it, however, the CEL 12, EGR, has consistently come on. I replaced my EGR valve with a like new verified functional one and now the light comes on sooner into a drive and is accompanied by some starting issues; often I have to crank it multiple times and give it gas. The idle is also a bit off, but the only CEL is still the egr. I have followed a couple of the simpler tests that the shop manual gives, but was wondering if anyone has any insight into what it could be. I don't believe that the egr pipes or threshold are clogged as I visually checked them and there was no visible buildup. I appreciate any advice.
01-13-2022, 02:33 PM | #2 |
The EGR shouldn't effect starting or idling, unless maybe it's stuck open. It shouldn't activate until the engine is warmed up, and at a steady cruise.
A faulty coolant temperature sensor (TW Sensor) can cause starting and idling problems. http://forums.acuralegend.org/showthread.php?t=27968 http://forums.acuralegend.org/showthread.php?t=34454 -Kennon |
01-14-2022, 07:32 PM | #3 |
Thanks for the response! I actually found and solved the starting/idling problem, had an electrical connector disconnected somehow. The problem I currently have is the CEL comes on within 5 minutes of driving.
01-15-2022, 11:30 AM | #4 |
You can download the service manual from the G1 DIY sticky.
It has a troubleshooting procedure for the EGR. -Kennon |
01-15-2022, 04:00 PM | #5 |
'87 L-Coupe 5-Speed Stock; Few Mods 445K Miles - original engine and drivetrain. Last edited by paulo57509; 01-15-2022 at 04:04 PM. |
FS: 1989 5 SPD Coupe | BDAZZG1 | Legend | 1 | 05-20-2015 08:22 AM |
6 speed clutch problems | omar | 2nd Gen. Legend General Discussion | 6 | 02-14-2013 03:37 AM |
5 speed manual problems | Canadian144 | 2nd Gen. Legend General Discussion | 6 | 01-06-2012 03:23 AM |
