12-13-2023, 02:33 PM | #1 |
Headlight switch issue (intermittent)
1988 Acura Legend 4-door base sedan
1. Headlights on?good. 2. With headlights on, I turn on the left turn signal: dash cluster lights turn off; the clock light goes from dim back to bright again, indicating headlights are off. 3. Next, I check the front?headlights remain on, but the rear lights are off. 4. With the signal off, if I turn the headlight switch off and on again, all goes back to working normally. 5. Note: the above issue doesn?t happen each time; sometimes, engaging the turn signal causes no issue. It?s intermittent. I know that certain replacement parts for this older Legend are difficult to find. Is there a way to repair this problem? Thanks. |
Headlight combination switch | JKLedbetter | 1st Gen. Legend General Discussion | 8 | 07-16-2021 09:19 AM |
Headlight Switch | BluePhoeniX | 1st Gen. Legend General Discussion | 4 | 12-22-2012 03:23 PM |
Headlight issue | kora04 | 2nd Gen. Legend General Discussion | 5 | 06-21-2012 07:05 PM |
