04-23-2010, 08:39 AM | #1 | |
G1 Fan
04-23-2010, 09:01 AM | #2 | |
04-23-2010, 09:15 AM | #3 |
G1 Fan
So you're up to three cars now? How big is your garage?
04-23-2010, 09:33 AM | #4 |
no just 2 cars FTM....my sedan and the 07 Civic....but we are looking into these other 2...my GF is a lil put off by the damaged one with problems blowing hoses...she likes the other coupe (pretty as she says) but its a 5spd and she cant drive that at all and has no desire to learn...its a toss....I may get the 5spdr and call it good as it it seems a solid runner and a decent price...but dealer...I hate dealers. when we move I might add a extra to have/play with......more just into getting ready to move...possibly heading for Texas as a perm resident
04-23-2010, 09:40 AM | #5 |
G1 Fan
Get the 5-spd, dude, you'll get more pleasure out of it fer sure. Also, less maintenance in the long run (ie: if the ECU goes out in it, you can use either a manual or auto type to replace it), and you won't have to worry about the sport-shift feature possibly causing any trouble (not saying it would, but my life exp with automatics is lousy, lol!).
Btw, if things don't work out with your gf, that fixer-upper would keep you occupied (no offense). |
04-23-2010, 10:11 AM | #6 |
G1 Fan
Thought of a buying tip for the fixer-upper crowd. If the owner will let you, check the ECU code lights. If there's no flashing going on, 10-1 the car will need either a relay or the connections are loose on the ECU (like what happened with me :P). Worst case scenario is a bad ECU, which runs close to $900 new, and used ones are a gamble sometimes.
The ECU on sedans is right under the passenger seat. If it's a coupe, you'll have to (carefully!) pull the carpet back a little in the passenger footwell to check the inspection window on the panel. If the red LED is flashing count the number of flashes and write it down. That's the code number (mine is flashing a 6, cooling system). |
04-23-2010, 10:21 AM | #7 | |
My 87 had no flashes (she let me check and was willing to allow me to go thru the car entirely prior to purchase....might help she was a doctor and cared for the car impeccably as can be seen in my pics....she had not one thing to hide on the car and I felt reasonably assured it was in quality shape...the low mileage coupe...on other hand...dealer car which means he knows precisely SQUAT about the car....it may run beautifully for a month and then rear a ugly hand...its more a gamble to me on that one...the other coupe i am looking at...well...known issues with the car and seem to be being disclosed.....I am just nervous about it since I cant actually START the car to hear anything....be real pissed if I drag it home and hear valves banging away from a blown belt or god knows what else she did to it But good heads up for future purchasers! |
09-10-2010, 12:49 AM | #8 |
Moo?
Wow...wish I had seen this 6.5 months ago when I bought my 88 sedan. I paid $1000 for it with the following:
rebuilt tranny rebuilt alternator 4 brand spankin new tires engine and clutch in great condition red with black leather interior 5-spd manual ecu showing code 12 with cel on (needs egr) right cv joint clicking cosmetic damage to left tail light rusted left front corner (right next to the hood) missing alarm fob needs 4 struts/shocks hole in exhaust pipes somewhere between header and muffler hood struts failed power antenna (motor works, hear it all the time...but no antenna) found later: right tie rod end loose timing belt/camshaft seals/crankshaft seal/water pump all need to be replaced radiator/heater hoses valve cover gaskets radiator cap shift shaft seal sway bar console clock intermittent sunroof leaks It's a work in progress, and I'm learning as I go. I get my oil changed at a shop cause they do a free inspection of my car and tell me whats wrong with it so I can go fix it elsewhere. Things I've done myself (with help): cap/rotor/plugs/wires/air filter replaced the clock stereo swap hood struts got lucky, cartoys had the alarm fob that i needed in stock and they got 1 in that day new radiator cap(that was the hardest thing so far ;-)) pulled 2 tail lights and 2 side marker lights want to make them clear working on the egr system right now intend to replace the radiator/heater hoses fuel filter is on the list as is valve cover gaskets and cleaning out sunroof drains replace power antenna Anyway, what do you all think? Did I get ripped off? In any case, I love the car, and it's a blast learning how to work on it. |
09-10-2010, 11:09 AM | #9 |
For $1,000, that's perfect espesially if they done most of the work.
My Build Thread Oh my gawd That jar better blow me twice and cook breakfast for $1000. |
06-17-2013, 04:13 PM | #10 |
Thanks for all this info. My 90 Legend Sedan Goldie has just started showing a few small spots of rust showing through the paint, on the rear wheel well. I just noticed it yesterday for the first time. Is there a solution for slowing or stopping the rust? Otherwise, the car is as close to mint as you can get, with just 36K miles and everything running perfect, and perfect interior.
Do we have a clear concise buyers guide for Gen 2 Legends? | onthe3rdday | 2nd Gen. Legend General Discussion | 8 | 02-20-2010 09:33 AM |
2nd Gen RL wheels on 2nd Gen Legend??? | KJLegend | 2nd Gen. Legend General Discussion | 18 | 12-29-2009 08:50 PM |
4piston 2nd gen RL calipers on 1st gen RL | OLD_HATCH | 1st Gen. RL Performance Enhancements | 16 | 11-06-2009 02:52 AM |
Buyer's Beware This Coupe!!!!! | EVAN8R | 2nd Gen. Legend General Discussion | 25 | 08-31-2009 07:45 AM |
