Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > Second Generation Legend -- 1991 - 1995 > 2nd Gen. Legend Performance Enhancements
Old 02-04-2011, 11:49 AM   #81
sean_b
91 coupe 92 sedan
sean_b's Avatar
Real Name: sean butler
sean_b is on a distinguished road
soooo still no reply, this is the best discussion on the whole site and there hasnt ben a rely in almost half a year?
91 coupe mods.
push button start
passenger seat delete CAI
straight pipe exhaust
Door panel Delete
sean_b is offline   Reply With Quote
Old 02-04-2011, 11:57 AM   #82
sean_b
91 coupe 92 sedan
sean_b's Avatar
if we put the throttle body on the very top it might work. or to make it still fit under the hood, we can have 2 throttle bodies. one on each side of the supercharger
91 coupe mods.
push button start
Door panel Delete
Old 02-04-2011, 12:12 PM   #83
OLD_HATCH
OLD_HATCH is on a distinguished road
that will up the cost, not to mrntion add more tuning variables.
another thing is that most of use are not willing to modify the hood just to fit a supercharger. It would really kill the look. If you plan on going all at racer you can do like the civic boys and cut it through the hood.
OLD_HATCH is offline   Reply With Quote
Old 02-04-2011, 12:44 PM   #84
well i might have said this before...
Most of these whipple and roots S/C (OEM) have a TB on the far end which would mean it would face the rear of the engine bay in a legend (firewall)
mounting a filter back there or running pipping would not be that easy but it might just work.
A did a more detailed post about this a few pages back iirc
Old 10-19-2011, 04:57 PM   #85
like no other
Getting It Done
like no other's Avatar
like no other will become famous soon enough
I never saw this thread before but off the top of my head I think there is enough room between the motor and the firewall to route the intake pipe. And put the filter to the right of the brake booster(where the charcoal can is).
hard work + dedication = perseverance
like no other is offline   Reply With Quote
Old 10-19-2011, 09:07 PM   #86
There is enough room..2.5 inchs pending heater valve/vis piping
Old 10-20-2011, 06:49 AM   #87
I'd need to check next time I'm working on mine.
M90 mounted where the lower plenum now is would delete VIS.
You'd need to check how to run oil feed etc, to the S/C
A setup like telion pointed out is still very attractive, Honda V6 generally responds awesome to M90 & M62 S/C's testament to that would be CTSC kits on C30A,C32B,J30A,J32A,J35A
Although there J kits are M62 and a bit on the small side for 3.5+ engines.
Twin AMR500 setup might be a bit complex but would have a nice show factor.
But that's going off-topic as that isn't basic in terms of piping, mounting and pulley.
They are how ever dirt cheap.
Old 10-20-2011, 07:20 AM   #88
Trust me it works... this is on a type 1
Old 10-21-2011, 01:09 AM   #89
that's going to be a very thigh fit remember you will have to run a TB there as well unless you remotely mount your TB more to where the current fuel filter is.
and figure out a way to position the tranny dip stick
Old 10-23-2011, 12:18 PM   #90
BestCoast
BestCoast's Avatar
BestCoast is on a distinguished road
why not just go the route they do on the ls series engines and run a prop shaft to the back and have the throttle body in the stock position? I think this would help in keeping everything compact and relocating the throttle body seems like it would be a mess. If somebody can get the width of the s/c body you could build a cardboard box the same size and measure the clearance between it and the head/upper half of the intake manifold. I'm sure the schematics are available online including ones for the prop shaft system.
Under Construction
BestCoast is offline   Reply With Quote
KSPO.Kontroll. Coilovers!! or TEIN BASIC Vipka9 Non-OEM Parts 1 03-25-2011 04:21 AM
ITB setup... What does it take??? DriftKingOF541 2nd Gen. Legend Performance Enhancements 5 03-13-2010 04:34 PM
G Bose Setup 89HondaLegend 1st Gen. Legend General Discussion 3 12-03-2009 06:56 AM
Site for Cheapest Tein Basic Damper Kit II KRUCKUS II 1st Gen. RL General Discussion 2 11-27-2009 07:11 PM
Anybody know basic physics? Riboflavin The Water Cooler 13 09-26-2009 05:32 PM
