Old 12-02-2009, 04:27 PM   #1
89HondaLegend
Old School
Default G1 Bose Setup
Wondering how the amplifiers are set up?
I have a BOSE HU, speakers and amps but I can not for the life of me get the amps to work or do anything for that matter.
When I dosconnect the stock HU and plug in the BOSE HU it powers up fine and plays music very faintly (no amps hooked up so it makes sense).
So there are 4 wires coming out of each amp, I assumed that two were +/- for power and the other two were +/- for speaker signal. So I go ahead and connect 12V to the amp and connect the speakers through the amp and I can't get a pop or even a crackle. Perhaps I have it wrong though?
Could anybody help me out with this?
Regards, Steve
Love to Love the Legend
89HondaLegend is offline   Reply With Quote
Old 12-02-2009, 07:24 PM   #2
awelliott
Senior Junior Member
Real Name: Tony
awelliott will become famous soon enough
Don't have time to research right now, but do you have the amplifier relay? It's located under the dash in the general vicinity of the main relay.
Briefly, at the amps the orange lead is the negatives from the HU, and the white leads are positive. Battery voltage that is switched through the amplifier relay is carried on the yel/red wires at the amplifier. And, of course, the black wire is for ground. The power and +/- for the speaker signals use the same pinouts at the back of the HU, though the color coding of the wires is different.
Are you certain that the amps your received are good? It's very, very common for those amps to go bad, even if they've been sitting on a shelf.
awelliott is offline   Reply With Quote
Old 12-03-2009, 06:15 AM   #3
reddLegend
peep the pic
reddLegend's Avatar
Real Name: S.L. Jones, Jr.
reddLegend is on a distinguished road
i know for a fact that you cannot get the speaker to pop through an amp. you can only do that to the speaker it self. that's about all the help i can give.
reddLegend is offline   Reply With Quote
Old 12-03-2009, 06:56 AM   #4
18 characters long
SquareBobPantsSponge
18 characters long's Avatar
Real Name: Dawson
I just tested mine, and.. HOLLY F'ING CRAP THEY'RE LOUD!!!! I didn't expect them to be that loud! I took a spare Buick radio I had laying around, and I was testing to see which speaker wires where what on a standard Kenwood speaker I've got, I took and hooked the Bose up to it, and scarred the stuff out of myself! O_O
Fut
My audio setup Wes Audio and Other Electronics 24 09-30-2009 06:39 PM
A TT setup lilke mine taken to the extreme Telion Other Cars 9 09-08-2009 09:46 AM
burlwood setup Biggg72 OEM Parts 2 08-14-2009 08:53 PM
Infinate Baffle Setup LegendJeff Audio and Other Electronics 5 07-04-2009 07:32 PM
