|  04-23-2010, 08:23 PM | #1 |
| Junior Member |  Help? High Idle When Warm
			I have a 91 ls automatic, i just did my HG's (220 miles ago) i bought the car with BHGS and don't know what other problems it could have had. when I start my car I wait for the idle to settle down to about 1000rpm that's all the further it will go down. once I drive for like 4 minutes the car idles fine in gear and neutral, but after like 15 minutes the car idles at 850rpm in drive, and about 1500 in neutral/park. The car also starts to downshift hard (due to high idle?) Things I have tried: Coolant bleed, I think I got all of the air out FIV adjusted down EACV vacuum lines car holds good temp. Any help is very appreciated, I am 16 and don't have a lot of $$ so i need to get my baby working right. Thanks |
|  04-23-2010, 09:10 PM | #2 |
| Junior Member Join Date: Jul 2009 Location: Omaha NE
				 Real Name: Jared Bauer  |  throttle cables?
			Ill bet you its the throttle cables going to the throttle body.  Check and adjust.  I had this same problem a coupe of times after doing a BHG. I was just in a hurry to get those cables on I wasn't adjusting them right.  Check the online service manual for help. edit: let me know. I could be wrong Hope that works |
|  04-23-2010, 09:16 PM | #3 | |
| Junior Member |   Quote:
  Ill let you know what happens Thanks   | |
|  04-25-2010, 08:44 AM | #4 |
| Junior Member |
			my throttle cables were at the factory mark but i tried adjusting and it didnt help, any other ideas?
| Bookmarks |
| Tags |
| coolant bleeding, eacv, fiv, high idle |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
|  Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| my idle revs up and down | 95pearlwhiteGS | 2nd Gen. Legend General Discussion | 30 | 11-15-2012 02:14 PM |
| Idle Help please!! | nowee2009 | 2nd Gen. Legend General Discussion | 11 | 04-23-2010 06:31 PM |
| confused about my idle need some help | Biggg72 | 2nd Gen. Legend General Discussion | 15 | 03-21-2010 11:11 PM |
| Strange squeek in rack when warm. | 18 characters long | 1st Gen. Legend General Discussion | 7 | 11-01-2009 10:42 AM |
| Key hard to turn and remove when COLD.. warm.. no problem | jhmcat | 1st Gen. Legend General Discussion | 4 | 10-10-2009 12:29 AM |
