Old 02-08-2011, 04:45 PM   #1
Nightshift
Nightshift's Avatar
Real Name: Wayne
Nightshift is on a distinguished road
Default Difference Between Bose 2100 and 2100 'Premium'?
I recently scavaged some parts off a clean '92 LS at a local junk yard. The center console Burlwood is perfect and while I was at it I pulled the Bose 2100. It just looked well cared for. Someone took enough care to print a label with the s/n and radio code and attached it to the bottom of the ash tray.
When I installed the Burlwood in the GS I figured I'd test the radio. Plugged it in, turned the key and pressed the power button; the antenna raises and the display reads 'CODE' in nice bright clear letters! Big Giant Smile ! ! !
Entered the code and everything went blank...
The question is... Since the GS and every Legend I own has the Bose 'Premium' system, is it incompatible with the 2100? Or is my 2100 I paid $15 for toast?
On the up side; I bought a bunch of stuff that day off 7 Legends. When I got home and looked over the receipt the Burlwood was free, they didn't charge me for it....
Is the radio junk or just incompatible??
WW-
'12 GMC Sierra SLT Crew Cab, '02 Lexus SC430
'94 LS 6-Speed Coupe, '94 GS 6-Speed
'95 GS Automatic (Formally lukin3)
'72 Buick Skylark Convert, Frame Off Resto
Nightshift is offline   Reply With Quote
Old 02-08-2011, 04:56 PM   #2
EvilRed92Legend
Cassis Red Pearl
EvilRed92Legend's Avatar
Real Name: Greg
EvilRed92Legend is on a distinguished road
They use different amps and are thus incompatible. I Have a "wrong one" in my garage too
Sigpic by bboarder711 ... 1992 KA7 LS 5spd ...
/\JDM Headlights/\Moonroof-Tilt Mod/\K&N Filter/\B+G Sport Springs/\Koni Red Struts/\Type-2 Calipers/\Sebring Exhaust/\
Originally Posted by Geneva_Jee
slow dimming light = luxury
Originally Posted by Beaner_Towel
use fingertips to shift, like you're playing with a boobie!
EvilRed92Legend is offline   Reply With Quote
Old 02-08-2011, 06:51 PM   #3
WW-
I would think that the amp wouldn't have anything to do with whether or not the HU accepts a code or not. The amp amplifies the power from the HU; it
doesn't accept or reject codes from what I've read. Don't throw it away yet, Wayne. Maybe it's the wrong code. Is the serial # still on the label? We can confirm the code # first.
Old 02-08-2011, 06:58 PM   #4
That sticker was put under the ashtray during PDI. The other one went on a card in the owner's manual.
If the radio was warrantied then the code might now be different... but I thought you got 3 chances at the code. Even with the display out you should be able to hit auto tune and get some channels. Try that too.
Old 02-09-2011, 04:18 PM   #5
Nightshift
Nightshift's Avatar
Real Name: Wayne
It accepted the code. Had it been the wrong code it would ask for it again.
I unplugged it and it did the same thing a second time. It's so clean, no wear on the buttons at all. Also got the antenna out of it ($13), it was in the fully down position so I assumed it worked and it does...
If the radio is junk it was $15, someday therewill be another Legend in the fold I can try it out in.
A little side story:
Took a friend that was visiting from Italy that week with me, I had scouted the yard the day before. He is a surgeon by trade, had the time of his life. Had never been to a junk yard before, I handed him the crowbar to break into the trunk of this Legend. He was in it in a few minutes... Leave it to the Italians!
The story he gets to tell his people... Goes all the way to America and gets taken to a junk yard, what a host!
And getting to break into a car.
WW-
Old 09-27-2016, 01:45 PM   #6
BayAreasFinest
Type 1 King
BayAreasFinest's Avatar
BayAreasFinest is on a distinguished road
I have the same issue with my original head unit in my 94 GS.
The head unit worked a few months ago and now after sitting for months it showed the exact symptoms listed above. I enter the correct code, it accepts it, and the screen goes blank. The antenna goes up like normal and when I push the power button the antenna goes back down as well. If I press the power button again the screen is blank still and the antenna goes up like normal, no sound or display coming from head unit.:dunno:
my fav legend is officially greekpower's legend, b/c his legend is the kind of legend, you just close your eyes, and imagine the coolest fucking legend possible
Type 1 stock NA full interior = 14.8 @ 93 MPH
Type 1 CAI NA and DR's full interior = 14.5 @ 94 MPH
My Legend = http://youtu.be/XimYbO6fvRs
BayAreasFinest is offline   Reply With Quote
Old 09-27-2016, 02:27 PM   #7
Based on what you have said, the display is just not working. Try turning it on and then tuning stations with the volume up and see what happens. Hit "seek" with the volume up and see if you hear sound. If you can see the word " code" clearly, then my theory is incorrect.
EDIT: in re-reading the above post #1, the "CODE" was bright. If that is the case, I'd say your radio is broken. Willman Electronics in Texas specializes in repairing them.
Old 09-27-2016, 10:25 PM   #8
srqlegend
srqlegend is on a distinguished road
Question G2 Legend Stereo FAQ
There is a G2 Legend Stereo FAQ that has loads on info in it. My GS was "retrofitted" by PO with the 2200 and whatever amplifier that went with it.
srqlegend is offline   Reply With Quote
Old 09-28-2016, 05:09 AM   #9
2200's have a built-in amp. Not sure what your PO did.:dunno:
Old 09-28-2016, 11:06 PM   #10
srqlegend
Default Bose 2200 + amp behind seat
Maybe the PO swapped in a 2200 when the amp died? I looked behind the seat and the amp is plugged in. :dunno:
FS: Bose 2100 Premium Head Units Olikado OEM Parts 4 12-06-2010 02:08 PM
Bose Premium 2100 no digits on display Legend95 2nd Gen. Legend General Discussion 4 09-28-2010 03:42 PM
FS: Bose 2100 premium Head-unit!! legend93g2 OEM Parts 6 08-14-2010 05:17 PM
Bose Premium 2100 Head Unit Olikado OEM Parts 1 06-22-2010 10:41 PM
Bose Premium 2100 Head Unit turix OEM Parts 7 12-30-2009 06:04 AM
