Old 03-18-2012, 04:33 PM   #1
merlinj79
merlinj79's Avatar
merlinj79 is on a distinguished road
Default Clutch Doesn't Disengage When Hot
My clutch pedal feels normal, but it didn't disengage when pushed all the way to the floor today.
I had a complete clutch job done about a month ago (including MC and SC). Today was rather hot and I drove around town for a while before this happened. I let the car cool down for a couple hours, and now it seems to work OK, but I'm reluctant to drive far.
The shop put in a clutch kit so hopefully the mechanical parts are all good...maybe it just needs to be bled again?
I'm on temp military duty away from home, so I don't have the tools to do much work myself.
1988 Legend LS Sedan
Stock Everything (except stereo).
merlinj79 is offline   Reply With Quote
Old 03-18-2012, 07:40 PM   #2
It does sound like you have air in the system. I would re-bleed the system.
Old 03-20-2012, 03:38 PM   #3
merlinj79
merlinj79's Avatar
They bled it, said no air came out. they couldn't duplicate the problem.
Today after it was warmed up I held the clutch in for a minute or so, and then I could feel it turning the input shaft with the clutch disengaged. Now I'm sure it's the input shaft dragging. Might have been caused the first time by me holding the clutch in while waiting for my garage door to open?
Looking in the shop manual (OEM) I can't see a needle bearing or bushing... there has to be one on the input shaft, right?
Old 03-20-2012, 03:46 PM   #4
What kind of fluid did they put in for the clutch reservoir? And is the fluid in the tranny at the right level?
Old 03-20-2012, 05:11 PM   #5
merlinj79
merlinj79's Avatar
Weeeeell...I ASSUME they used DOT 3. They seem fairly reputable, I doubt they would put DOT 5 in a 1988.
It doesn't leak, and I filled the tranny less than a year ago. Should I check that again? Does tranny oil lube the input shaft at the flywheel?
Thks
Old 03-20-2012, 07:13 PM   #6
stephen
stephen is on a distinguished road
There is no pilot bearing or bushing. Usually there isn't on front wheel drive.
stephen is offline   Reply With Quote
Old 03-20-2012, 07:15 PM   #7
stephen
Thks
They would have drained the trans fluid when they did the clutch. You might check the oil level in the transmission. Honda manual transmission fluid works
a lot better than engine oil.
Old 03-22-2012, 12:15 PM   #8
merlinj79
merlinj79's Avatar
Oh. Does the input shaft just ride in the flywheel hole? How is it lubricated?
Old 03-23-2012, 09:45 AM   #9
stephen
There are bearings inside the transmission case on the front and back of the shaft. The end of the input shaft isn't touching anything and needs no lubrication.
Old 03-24-2012, 01:22 PM   #10
merlinj79
merlinj79's Avatar
OK, I get it. So really this has to be the clutch disc still engaging...there's no way the input shaft can bind at the flywheel.
Could this be a bad clutch disc, maybe dragging on the input shaft? Not sure how it could do that with the pedal all the way on the floor.
How hot is it where you are??!?! Aking The Water Cooler 47 07-21-2011 09:35 PM
Removing Clutch/Swap to 5-Speed Clutch brettallen59 2nd Gen. Legend General Discussion 1 01-10-2011 08:55 AM
How hot does...... XxWEISERxX 2nd Gen. Legend General Discussion 17 07-07-2010 07:19 PM
Fired for being Hot? cakes The Water Cooler 47 06-11-2010 06:07 AM
This is one hot G1.... IGotALemon The Water Cooler 15 08-29-2009 09:55 AM
