Old 10-23-2011, 12:42 PM   #91
Originally Posted by BestCoast View Post
why not just go the route they do on the ls series engines and run a prop shaft to the back and have the throttle body in the stock position? I think this would help in keeping everything compact and relocating the throttle body seems like it would be a mess. If somebody can get the width of the s/c body you could build a cardboard box the same size and measure the clearance between it and the head/upper half of the intake manifold. I'm sure the schematics are available online including ones for the prop shaft system.
Genius! awesome idea,
Yesterday i was looking with my mechanic to some SC setups one using a V12 merc engine other was a LS6, we where wondering how they converted the TB setup.
I btw i have detailed drawings for the S/C's
I'm going to upload them right away
Old 10-23-2011, 12:43 PM   #92
hmm forum upload feature is a pita,
anyway this gives a good idea:
CAD screenshot:
Old 10-23-2011, 12:47 PM   #93
BestCoast
BestCoast's Avatar
BestCoast is on a distinguished road
^awesome man I think creating a mock up s/c would be the best way to figure this out. For cooling the air you could run a laminova system either in the upper chamber of the manifold or if space allows, you could create a small plate to sit between the s/c and the upper manifold that holds the laminova cores.
Under Construction
BestCoast is offline   Reply With Quote
Old 10-23-2011, 12:50 PM   #94
BestCoast
BestCoast's Avatar
Here is the nsx laminova intercooler setup from SOS:
http://www.scienceofspeed.com/produc...cooler_800.jpg
Edit: heres another view: http://www.scienceofspeed.com/produc...sembly_800.jpg
Under Construction
Old 10-23-2011, 12:53 PM   #95
Old 10-23-2011, 12:55 PM   #96
yeah i was playing around with that idea for a while, my company specializes in NSX's the laminova works great on them as do topmount eaton's
anyway that would infact be the same way the OEM honda intercooler works on a C20AT turbo legend
Old 10-23-2011, 12:58 PM   #97
BestCoast
BestCoast's Avatar
exactly except with the s/c flipped so it sits under the stock manifold so you can keep your hood clearance.
Edit: The problem I see with a topmount is that the manifold would have to be a one-off. It all depends on how much work you want to put in to it.
Under Construction
Old 10-23-2011, 01:00 PM   #98
indeed this will also allow for long runners keeping torque where it should be
Old 10-23-2011, 01:05 PM   #99
hmm now running the return shaft might be problem since down low there isnt enhough space between the heads you might need to revert to running it trough the plenum,
Which isn't a disaster as you could incorporate it in to the top of the plenum chamber, working as a splitter.
IF the shaft would run in the center of the plenum which it doesn't
If i only head a spare manifold here i'd mock it up.
preferably you'd use 3 sprockets to switch direction since that will mean zero maintenance although costly.
Since running a belt there will just make for some annoying maintenance, chain drive would be more practical if you can get a custom timing chain that short.
Old 10-23-2011, 01:18 PM   #100
BestCoast
BestCoast's Avatar
you could offset the s/c to allow room for the shaft to run. I would think sticking with the tried and true belt drive would keep things less complicated.
Under Construction
KSPO.Kontroll. Coilovers!! or TEIN BASIC Vipka9 Non-OEM Parts 1 03-25-2011 04:21 AM
ITB setup... What does it take??? DriftKingOF541 2nd Gen. Legend Performance Enhancements 5 03-13-2010 04:34 PM
G Bose Setup 89HondaLegend 1st Gen. Legend General Discussion 3 12-03-2009 06:56 AM
Site for Cheapest Tein Basic Damper Kit II KRUCKUS II 1st Gen. RL General Discussion 2 11-27-2009 07:11 PM
Anybody know basic physics? Riboflavin The Water Cooler 13 09-26-2009 05:32 PM
